Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
- Date: Sat, 04 Apr 2015 11:21:12 -0400
On 04/02/2015 03:08 PM, Jonathan Leivent wrote:
Here's a version that should work in 8.4 (I only have 8.5 installed, so I can't check it), and which uses the evar direct-list trick instead of context searches. Because it does not use tactic-in-term, proof term impact is quite large, but it beta reduces out easily - as can be seen in the demo.
-- Jonathan
I installed 8.4 to check this. It didn't work, but was fixable (attached). I had to rely on case_eq for the hard @eq case that Jason pointed out, even though case_eq looks like it has a bug with respect to the equality it generates (eq_refl = eq_refl in the @eq case) - but maybe that bug is just why it can handle @eq in 8.4. 8.4 also needs those extra arg-less instantiates.
-- Jonathan
Ltac head_of term := lazymatch term with | ?H _ => head_of H | _ => term end. Ltac get_value H := eval cbv delta [H] in H. Inductive things : Prop := | More{T}(h:T)(t:things) | NoMore. Ltac start_things H := evar (H:things). Ltac add_thing t H := instantiate; instantiate (1:=More t _) in (Value of H). Ltac end_things H := instantiate; instantiate (1:=NoMore) in (Value of H). Ltac pose_ctors type H := start_things H; assert ((forall T, T) -> True) as _ by (let Q := fresh in intro Q; let D := fresh in let rec f t := first [pose (D:=Q t) | f (t (Q _))] in f type; case_eq D; intros; lazymatch goal with | _ : _ = ?c |- _ => let C:=head_of c in add_thing C H end; exact I); end_things H. (*Tests*) Inductive Weird : nat -> Set := | weird0 : Weird 0 | weird1(b : bool) : Weird 1 | weird2(n : nat) : Weird (n - 2) | weird3(n : nat)(w : Weird (S n)) : n > 2 -> Weird n. Inductive Strange(x: nat)(w : Weird x) : Set := | strange0 | strange1 (b:bool). Lemma demo : True. pose_ctors Weird W. pose_ctors Strange R. pose_ctors False F. pose_ctors bool B. pose_ctors nat N. pose_ctors @eq E. pose_ctors list L. pose_ctors prod P. Show Proof. exact I. Defined. Print demo. Definition demo2 := Eval lazy beta delta [demo] in demo. Print demo2.
- RE: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Soegtrop, Michael, 04/01/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 04/01/2015
- RE: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Soegtrop, Michael, 04/02/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 04/02/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 04/04/2015
- [Coq-Club] Type:Type and turning of universe consistency check, Erik Palmgren, 04/12/2015
- Re: [Coq-Club] Type:Type and turning of universe consistency check, Jason Gross, 04/12/2015
- Re: [Coq-Club] Type:Type and turning of universe consistency check, Erik Palmgren, 04/12/2015
- Re: [Coq-Club] Type:Type and turning of universe consistency check, Vladimir Voevodsky, 04/13/2015
