coq-club - Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
  • Date: Thu, 02 Apr 2015 10:11:43 -0400
On 04/02/2015 04:32 AM, Soegtrop, Michael wrote:
Dear Jonathan,
I am making some use of 8.5 features, so if the 8.5 version has a cleaner
result, I would use the 8.5 version. But I am also curious to see how you
solved it in 8.4.
Regarding context searches: I am interested in proof automation performance
and context searches with unspecific search patterns and heavy follow up
tactics have a bad impact on performance. But context searches with
restrictive patterns or lightweight follow up tactics or properly gated
heavier tactics are fine. On the other hand everything which leads to good
search tree pruning or more stable proof search is usually worth the effort.
What counts is ease of use, stability and the final performance. I am quite
pragmatic in reaching these goals.
In that case, I have attached the 8.5 version. Roughly - the 8.4 version uses refine instead of tactic-in-term to build constrs out of tactics - as the "collect_things" technique used in these tactics requires a constr to be built that contains the inductive type's match expression. However, the alternate evar-based mechanism I referred to would perhaps also work in 8.4, but not as easily (I don't have an 8.4 version of Coq available to test - so I am saying this based only on faulty memory). That evar-based mechanism avoids the context searches by directly building a "list" of the constructor names by selective instantiation of an evar, and avoiding the need for context searching a constr - hence no need for the constr.
I see below that you are not using tactic-in-terms - favoring instead asserts - to test conditions. Note that asserts, like refines and anything else other than tactic-in-term - add to the ongoing proof term. Which you can see at any point in a proof by the command "Show Proof". If you call IsInductiveType successfully many times during a single proof, the result will be that the proof term will have one unused function/arg (in the case of assert) for every such successful call. All of these would reduce out via beta reduction - but just be warned if you ever unfold such a proof before doing any beta reduction on it that it will be a mess. Enhancement request 4112 is about this.
Here is what IsInductiveType would look like with tactic-in-term instead of assert:
Ltac IsInductiveType type :=
let unused:=constr:($(
let val:=fresh in
intro val;
destruct val;
exact I)$ : (type -> True)) in idtac.
Note also the "let val:=fresh" - else there is a risk of a name clash.
-- Jonathan
For the time being I think I will go with Ltac as far as possible. Meanwhile
I am quite happy with it. I try to delay plugin development until sometime
later when my project grows larger.
Here is the final "IsLiteralTerm" tactic which is based on your is_ctor
tactic (called IsCtorSym below).
(* Check if the given term is an inductive type *)
let H:=fresh in
(* Using type as a precondition allows us to get a value of the type
during the proof of the assert *)
assert (type -> True) as H by (
(* val is a opaque value of type 'type' *)
intros val;
(* See if val can be destructed, if so solve the goal *)
destruct val; exact I
(* clear the hypothesis generated by the assert *)
clear H.
(* Check if a complete term contains only constructors and inductive type
names like a polymorphic list type argument.
This includes numbers, lists of numbers, strings, booleans, ... *)
Ltac IsLiteralTerm term := lazymatch term with
| ?H ?A1 =>
(* Debug idtac "f2" H A1; *)
IsLiteralTerm H;
IsLiteralTerm A1
| ?H =>
(* Debug idtac "f1" H; *)
first [ IsCtorSym H | IsInductiveType H ]
end.
Best regards,
Michael
(*A problem with option (Some, None) is that it is in Type, and so is
restricted in ways that inductives in Prop would not be.  For example,
the term "Some (@Some)" does not type check.  Even if it did work -
being in Type instead of Prop - it would possibly impact extraction,
depending on where it is used.  So, instead of using option, we use
"thing" below (note that "Something (@Something)" does type check).
Since the intent of "thing" is that instances are parsed via Ltac
matches, having it in Prop is not restrictive:*)
Inductive thing : Prop :=
| Something{T}(x:T)
| Nothing.
(*Collect all X's that appear as [Something X] anywhere within the
term (failing when an X is under binders) into a single [Something
X-tuple], or Nothing if there are no [Something X]'s:*)
Ltac collect_things term :=
  let rec f t s :=
      lazymatch t with
      | context C[Something ?S] =>
        (*replace found Something with Nothing so it isn't found
        again*)
        let t':=context C[Nothing] in
        (*Either continue the existing Something tuple s, or start one
        if s is Nothing*)
        lazymatch s with
        | Something ?Ss => f t' (Something (Ss, S))
        | Nothing => f t' (Something S)
        end
      | context [Something] =>
        (*if this pattern matches when the above one doesn't, then
          that must mean that the arg is trapped under binders - which
          the caller should have prevented*)
        fail "collect_things: Something is under binders in" t
      | _ => s
      end in
  f term Nothing.
(*A quick test for the existence of Something x in term - as with
collect_things, this does not work when x is under binders - but
unlike with collect_things, this does not take the time to check for
such problems (which shouldn't exist if the caller has done its
job):*)
Ltac has_something x term :=
  lazymatch term with context [Something x] => idtac end.
Ltac head_of term :=
  lazymatch term with
  | ?H _ => head_of H
  | _ => term
  end.
(*The opposite of "head_of" - return an elaborated version of the
constr term with as many of its args filled in by tac as possible:*)
Ltac elaborate term tac :=
  (*Use "match I with" (the discriminee doesn't matter) as a constr
  version of "first":*)
  match I with
  | _ => elaborate (term $(tac)$) tac
  | _ => term
  end.
(*If the hypothesis H has a value (body), return it unreduced, else
fail.  Uses delta-only reduction restricted to H itself to prevent
further reduction.  Note that if H is a fixpoint, cbv won't unfold it
further - so this reduction is restricted to removing the outermost H
only, which is just what we want:*)
Ltac get_value H := eval cbv delta [H] in H.
Local Definition Quodlibet := forall T, T.
(*Use a "magical sandbox" to find the constructors of an inductive
type.  The sandbox (within a tactic-in-term) is provided with an
instance of Quodlibet (Q) - which can be used to instantiate any type.
The argument tac takes two args: Q and a fresh hypothesis name H - tac
must pose as H an instance of the targeted inductive type, using Q as
needed to fill in any arguments.  The constr that ctors_internal
returns is a function term containing only a match expression with
Something c in each branch for all constructor symbols c:*)
Local Ltac ctors_internal tac :=
  (*reduce the resulting constr - both to get around bugs like 4165,
  and to make searching it faster*)
  eval cbv in
    ($(let Q:=fresh in
       intro Q; (*Q : Quodlibet - for filling any holes*)
       let H:=fresh in
       tac Q H; (*must pose discriminee as H, using Q*)
       let H2:=fresh in
       pose H as H2; (*keep a copy to examine after destructing*)
       tryif destruct H then idtac
       else (let t:=type of H in
             let th:=head_of t in
             fail "ctors_internal:" th "is not an inductive type");
       (*After the destruct of H, H2 in each branch (subgoal) will be
       the constructed instance - with a constructor symbol at its
       head:*)
       let C:=get_value H2 in
       let c:=head_of C in
       exact (Something c))$ : Quodlibet -> thing).
(*sym is tested to see if it is the head symbol of a constructor of an
inductive type*)
Ltac is_ctor sym :=
  let tac Q H :=
      (*use Q to fill in any args sym might have:*)
      let sym':=elaborate sym ltac:(apply Q) in
      tryif pose sym' as H then idtac
      else fail "is_ctor:" sym "is not even a valid term" in
  let C:=ctors_internal tac in
  (*search for "Something sym" in C:*)
  tryif has_something sym C then idtac
  else fail "is_ctor:" sym "is not a constructor symbol".
(*Return a constr that is either "Something [tuple of constructor
symbols of type]" or "Nothing" if type is inductive but has no
constructors (as with False). *)
Ltac ctors type :=
  let tac Q H :=
      let type':=elaborate type ltac:(apply Q) in
      tryif assert type' as H by apply Q then idtac
      else fail "ctors:" type "is not a valid type" in
  collect_things C.
(*Like ctors, but be permissive about x - it can be anything that can
be elaborated into an inductive type:*)
Ltac ctors' x :=
  (*Allow x it to be:
    - an inductive type (nat)
    - a term of an inductive type (42)
    - a function returning an inductive type (list)
    - a type of a function returning an inductive type (bool->nat)
    - a function returning a term of an inductive type (fun x => x+1)
    - a function returning a type of a - ah - you get the idea
  let tac Q H :=
      let x':=elaborate x ltac:(apply Q) in
      first [ assert x' as H by apply Q
            | let tx:=type of x' in
              assert tx as H by apply Q
            | fail 1 "ctors':" x "is not a valid type or term"];
      repeat specialize (H (Q _)) in
  collect_things C.
(*Some tests*)
Inductive Weird : nat -> Set :=
| weird0 : Weird 0
| weird1(b : bool) : Weird 1
| weird2(n : nat) : Weird (n - 2)
| weird3(n : nat)(w : Weird (S n)) : n > 2 -> Weird n.
Inductive Strange(x: nat)(w : Weird x) : Set :=
| strange0
| strange1 (b:bool).
Variable T:Type.
Variable F:T.
Variable G:nat.
Record rec : Set := {recfield : nat }.
Record rec2(n : nat) : Type := makerec2 { }.
Goal True.
let x:=ctors rec in idtac x.
is_ctor Build_rec.
let x:=ctors rec2 in idtac x.
is_ctor makerec2.
let x:=ctors' nat in idtac x.
let x:=ctors' 0 in idtac x.
let x:=ctors' (fun t:Type => (forall b:bool, list t)) in idtac x.
let x:=ctors' (fun x => x+2) in idtac x.
let x:=ctors' {|recfield := 0|} in idtac x.
Fail is_ctor F.
Fail ctors T.
Fail ctors F.
Fail is_ctor G.
is_ctor @None.
is_ctor Some.
is_ctor @eq_refl.
let x:=ctors @eq in idtac x.
let x:=ctors @prod in idtac x.
is_ctor @pair.
let x:=ctors option in idtac x.
let x:=ctors thing in idtac x.
let x:=ctors False in idtac x.
let x:=ctors bool in idtac x.
let x:=ctors list in idtac x.
is_ctor cons.
is_ctor 0.
Fail is_ctor (@cons nat).
is_ctor @cons.
is_ctor S.
Fail is_ctor (cons 1 nil).
Fail is_ctor 1.
Fail is_ctor X.
let x:=ctors (list nat) in idtac x.
let x:=ctors nat in idtac x.
let x:=ctors Weird in idtac x.
is_ctor weird3.
let x:=ctors Strange in idtac x.
exact I.
Show Proof.
Qed.
