Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure
- Date: Thu, 02 Apr 2015 15:08:30 -0400
On 04/02/2015 10:11 AM, Jonathan Leivent wrote:
... Roughly - the 8.4 version uses refine instead of tactic-in-term to build constrs out of tactics - as the "collect_things" technique used in these tactics requires a constr to be built that contains the inductive type's match expression. However, the alternate evar-based mechanism I referred to would perhaps also work in 8.4, but not as easily (I don't have an 8.4 version of Coq available to test - so I am saying this based only on faulty memory). That evar-based mechanism avoids the context searches by directly building a "list" of the constructor names by selective instantiation of an evar, and avoiding the need for context searching a constr - hence no need for the constr.
Here's a version that should work in 8.4 (I only have 8.5 installed, so I can't check it), and which uses the evar direct-list trick instead of context searches. Because it does not use tactic-in-term, proof term impact is quite large, but it beta reduces out easily - as can be seen in the demo.
-- Jonathan
Ltac head_of term := lazymatch term with | ?H _ => head_of H | _ => term end. Ltac get_value H := eval cbv delta [H] in H. Inductive things : Prop := | More{T}(head:T)(tail:things) | NoMore. Ltac elaborate term Q := match I with | _ => elaborate (term (Q _)) Q | _ => term end. Ltac pose_ctors type H := evar (H:things); assert ((forall T, T) -> True) as _ by (intro Q; let type':=elaborate type Q in let D:=fresh in assert type' as D by apply Q; pose D as D2; destruct D; let c:=get_value D2 in let C:=head_of c in instantiate (1:=(More C _)) in (Value of H); exact I); instantiate (1:=NoMore) in (Value of H). Inductive Weird : nat -> Set := | weird0 : Weird 0 | weird1(b : bool) : Weird 1 | weird2(n : nat) : Weird (n - 2) | weird3(n : nat)(w : Weird (S n)) : n > 2 -> Weird n. Lemma demo : True. pose_ctors Weird W. pose_ctors things T. pose_ctors False F. pose_ctors (@eq) E. pose_ctors bool B. pose_ctors nat N. Show Proof. exact I. Defined. Print demo. Definition demo2 := Eval lazy beta delta [demo] in demo. Print demo2.
- RE: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Soegtrop, Michael, 04/01/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 04/01/2015
- RE: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Soegtrop, Michael, 04/02/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 04/02/2015
- Re: [Coq-Club] Term classification in ltac: has_var / is_constr / term complexity measure, Jonathan Leivent, 04/04/2015
- [Coq-Club] Type:Type and turning of universe consistency check, Erik Palmgren, 04/12/2015
- Re: [Coq-Club] Type:Type and turning of universe consistency check, Jason Gross, 04/12/2015
- Re: [Coq-Club] Type:Type and turning of universe consistency check, Erik Palmgren, 04/12/2015
- Re: [Coq-Club] Type:Type and turning of universe consistency check, Vladimir Voevodsky, 04/13/2015
