- To: Coq-Club Club <coq-club AT inria.fr>
- Subject: [Coq-Club] Type Casting
- Date: Tue, 28 Apr 2015 12:46:04 +0100
I am unclear about Coq's type casting.
Consider
Check (cons: forall (A:Set), A -> list A -> list A).
(fun A : Set => cons (A:=A)):forall A : Set, A -> list A -> list A
: forall A : Set, A -> list A -> list A
It looks like the cast [ (cons: forall (A:Set), A -> list A -> list A).] is
a meta-notation for the eta-expansion. Then why is the cast still in the
term?
Now consider
Goal (cons: forall (A:Set), A -> list A -> list A) =
cbv beta.
Goal is:
(fun A : Set => cons (A:=A)) = (fun A : Set => cons (A:=A))
The cast was removed even though no beta steps were taken. What is
the official story about when casts are removed in Coq?
Finally consider
Goal (cons: forall (A:Set), A -> list A -> list A) = cons.
The Goal is
((fun A : Set => cons (A:=A)):forall A : Set, A -> list A -> list A) =
Why was the RHS eta expanded in this way? This is not the goal I
entered; this goal is true (solved by reflexivity), but the tactic
constr_eq (cons: forall (A:Set), A -> list A -> list A) cons.
fails.
Best,
Randy
- [Coq-Club] Type Casting, Randy Pollack, 04/28/2015
- Re: [Coq-Club] Type Casting, Matthieu Sozeau, 04/28/2015
- Re: [Coq-Club] Type Casting, Randy Pollack, 04/28/2015
- Re: [Coq-Club] Type Casting, Randy Pollack, 04/29/2015
- Re: [Coq-Club] Type Casting, Guillaume Melquiond, 04/29/2015
- Re: [Coq-Club] Type Casting, Randy Pollack, 04/30/2015
- Re: [Coq-Club] Type Casting, Matthieu Sozeau, 04/30/2015
