coq-club - Re: [Coq-Club] Type Casting
  • To: Coq-Club Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] Type Casting
  • Date: Thu, 30 Apr 2015 15:53:07 +0100
Thanks Guillaume, that was informative.
> Casts have no computational meaning, they are just meant as hints
> (and even then, the type checker tends to ignore them unless they ask
> for a specific reduction machinery, so they are basically just hints for
> the pretyper).
Then why isn't casting removed from the typechecked terms in my example?
Best,
Randy
On Wed, Apr 29, 2015 at 10:33 AM, Guillaume Melquiond
<guillaume.melquiond AT inria.fr>
wrote:
> On 29/04/2015 11:11, Randy Pollack wrote:
>> This "answer" doesn't explain either of the observations I asked about:
>>> Type inference is as you would expect: Γ |- t : A /\ A =c B ----> Γ |-
>>> (t
>>> :c B) : B. The :c can be just regular kernel conversion or call to a VM
>>> (bytecode or native). Reduction ignores casts entirely (AFAICT).
>> Type inference apparently causes eta-expansion of the term t, but
>> Matthieu's purported type inference rule doesn't change t.
> Type inference does not cause eta-expansion, per se. But type coercion does.
> Your term is somehow ill-typed, since cons has type "Type ->" while your
> cast forces it to have type "Set ->". So the pretyper performs an
> eta-expansion.
> Disclaimer: I am no specialist of Coq's type system, and it might well be
> that, according to the typing rules, the term is well-typed, even without an
> eta-expansion. But the pretyper at least seems to think it needs to put an
> eta-expansion there for the term to be well-typed.
>> Apparently reduction causes the cast "term constructor" to be dropped,
>> at least in some cases, which is not the same as ignoring casts
>> entirely.
> Casts have no computational meaning, they are just meant as hints (and even
> then, the type checker tends to ignore them unless they ask for a specific
> reduction machinery, so they are basically just hints for the pretyper). As
> a consequence, they can be dropped or ignored or whatever.
>> Finally, consider again the goal command
>> Goal (cons: forall (A:Set), A -> list A -> list A) = cons.
>> Coq shows the goal to be
>> ((fun A : Set => cons (A:=A)):forall A : Set, A -> list A -> list A)
>> Why is the RHS eta-expanded?
> Because of type coercion, again. Since both sides of the equality are
> supposed to have the same type, and since the left-hand side has type "Set
> ->" (because of your explicit cast), the pretyper of Coq decides to coerce
> the right-hand side to this type using an eta-expansion.
> Best regards,
> Guillaume
