- From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Type Casting
- Date: Wed, 29 Apr 2015 11:33:09 +0200
On 29/04/2015 11:11, Randy Pollack wrote:
This "answer" doesn't explain either of the observations I asked about:
Type inference is as you would expect: Γ |- t : A /\ A =c B ----> Γ |- (t
:c B) : B. The :c can be just regular kernel conversion or call to a VM
(bytecode or native). Reduction ignores casts entirely (AFAICT).
Type inference apparently causes eta-expansion of the term t, but
Matthieu's purported type inference rule doesn't change t.
Type inference does not cause eta-expansion, per se. But type coercion does. Your term is somehow ill-typed, since cons has type "Type ->" while your cast forces it to have type "Set ->". So the pretyper performs an eta-expansion.
Disclaimer: I am no specialist of Coq's type system, and it might well be that, according to the typing rules, the term is well-typed, even without an eta-expansion. But the pretyper at least seems to think it needs to put an eta-expansion there for the term to be well-typed.
Apparently reduction causes the cast "term constructor" to be dropped,
at least in some cases, which is not the same as ignoring casts
entirely.
Casts have no computational meaning, they are just meant as hints (and even then, the type checker tends to ignore them unless they ask for a specific reduction machinery, so they are basically just hints for the pretyper). As a consequence, they can be dropped or ignored or whatever.
Finally, consider again the goal command
Goal (cons: forall (A:Set), A -> list A -> list A) = cons.
Coq shows the goal to be
((fun A : Set => cons (A:=A)):forall A : Set, A -> list A -> list A) =
Why is the RHS eta-expanded?
Because of type coercion, again. Since both sides of the equality are supposed to have the same type, and since the left-hand side has type "Set ->" (because of your explicit cast), the pretyper of Coq decides to coerce the right-hand side to this type using an eta-expansion.
Best regards,
Guillaume
- [Coq-Club] Type Casting, Randy Pollack, 04/28/2015
- Re: [Coq-Club] Type Casting, Matthieu Sozeau, 04/28/2015
- Re: [Coq-Club] Type Casting, Randy Pollack, 04/28/2015
- Re: [Coq-Club] Type Casting, Randy Pollack, 04/29/2015
- Re: [Coq-Club] Type Casting, Guillaume Melquiond, 04/29/2015
- Re: [Coq-Club] Type Casting, Randy Pollack, 04/30/2015
- Re: [Coq-Club] Type Casting, Matthieu Sozeau, 04/30/2015
