- To: Coq-Club Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Type Casting
- Date: Tue, 28 Apr 2015 14:17:40 +0100
Hi Matthieu
> The cast is a term constructor.
What are the rules for typing and computation of cast terms? That
would answer my questions.
Randy
On Tue, Apr 28, 2015 at 1:16 PM, Matthieu Sozeau
<mattam AT mattam.org>
wrote:
> Hi Randy,
> On Tue, Apr 28, 2015 at 7:46 AM Randy Pollack
> <rpollack AT inf.ed.ac.uk>
> wrote:
>> I am unclear about Coq's type casting.
>> Consider
>> Check (cons: forall (A:Set), A -> list A -> list A).
>> (fun A : Set => cons (A:=A)):forall A : Set, A -> list A -> list A
>> : forall A : Set, A -> list A -> list A
>> It looks like the cast [ (cons: forall (A:Set), A -> list A -> list A).]
>> is
>> a meta-notation for the eta-expansion. Then why is the cast still in the
>> term?
>> Now consider
>> Goal (cons: forall (A:Set), A -> list A -> list A) =
>> cbv beta.
>> Goal is:
>> (fun A : Set => cons (A:=A)) = (fun A : Set => cons (A:=A))
>> The cast was removed even though no beta steps were taken. What is
>> the official story about when casts are removed in Coq?
> The story is you shouldn't expect any tactic to preserve them. They're
> "just" hints to drive conversion.
>> Finally consider
>> Goal (cons: forall (A:Set), A -> list A -> list A) = cons.
>> The Goal is
>> ((fun A : Set => cons (A:=A)):forall A : Set, A -> list A -> list A) =
>> Why was the RHS eta expanded in this way? This is not the goal I
>> entered; this goal is true (solved by reflexivity), but the tactic
> The coercion mechanism introduces those eta-expansions on the fly during
> refinement even though no actual coercion could be found after the
> expansion, i.e A -> list A -> list A becomes simply convertible with A ->
> list A -> list A. The coercion goes from Π A : Type, ... to Π A : Set ...
> here.
>> constr_eq (cons: forall (A:Set), A -> list A -> list A) cons.
> They aren't: the lhs is actually eta-expanded to match the casts' type,
> while the rhs stays a cons : forall A : Type, A -> list A -> list A.
> constr_eq rightly says they're different terms.
> Hope this helps,
> -- Matthieu
- [Coq-Club] Type Casting, Randy Pollack, 04/28/2015
- Re: [Coq-Club] Type Casting, Matthieu Sozeau, 04/28/2015
- Re: [Coq-Club] Type Casting, Randy Pollack, 04/28/2015
- Re: [Coq-Club] Type Casting, Randy Pollack, 04/29/2015
- Re: [Coq-Club] Type Casting, Guillaume Melquiond, 04/29/2015
- Re: [Coq-Club] Type Casting, Randy Pollack, 04/30/2015
- Re: [Coq-Club] Type Casting, Matthieu Sozeau, 04/30/2015
