coq-club - Re: [Coq-Club] Strange obligations in Coq proof on vectors
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Strange obligations in Coq proof on vectors
  • Date: Tue, 5 May 2015 23:18:18 -0700
Hello,
This appears to be a bug in Program, but it works correctly in Coq 8.5. So one option would be to upgrade (either to latest git or to one of the beta releases; I confirmed that this works correctly in both 8.5beta1 and 8.5beta2).
Hope this helps,
James
On Tue, May 5, 2015 at 11:00 PM, Vadim Zaliva <vzaliva AT cmu.edu> wrote:
Hi!
Consider this simple definition:
Require Import Coq.Vectors.Vector.
Require Import Omega.
Require Import ArithRing.
Program Definition TestOK (n pad:nat) (v:Vector.t nat n) : Vector.t nat ((S pad)*n) :=
  match n with
    | 0 => Vector.nil nat
    | S p => const 0 ((S pad) + ((S pad)*p))
  end.
Next Obligation.
  ring.
Defined.
Now, I am replacing const in S p case with equivalent concatenation of two consts:
Program Definition TestERR (n pad:nat) (v:Vector.t nat n) : Vector.t nat ((S pad)*n) :=
  match n with
    | S p => append (const 0 (S pad)) (const 0 ((S pad)*p))
  end.
Next Obligation.
It now asks me to prove an obligation:
S pad = S p
Which does not make sense! A quick check of types shows that they indeed match:
Variable p pad : nat.
Check const 0 ((S pad) + ((S pad)*p)).
Check append (const 0 (S pad)) (const 0 ((S pad)*p)).
This is an artificial example which shows simplified case of a problem I am facing as a part of a more complex proof. I am looking for any explanations on why this is happening and how this could be avoided. Thanks!
Sincerely,
Vadim
