coq-club - Re: [Coq-Club] Strange obligations in Coq proof on vectors
  • Cc: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Strange obligations in Coq proof on vectors
  • Date: Wed, 6 May 2015 14:37:33 +0200
As the others have said, it seems to be a problem with "Program".
I tried to rewrite TestERR without using Program.
I use the "Convoy Pattern" idea to not lose the info that n=0 in the first case and n=S n' in the second case.
I had to convince the type checker that
* when n=0 then t nat 0  actually is equal  t nat ((S pad)*n, and
* when n=S n; then  t nat (S pad + (S pad * n')) -> t nat ((S pad)*n)
To do that, I defined two functions, f1 and f2 that took a term of the first type and returned the second type.
My question is:  is there a more elegant way to do this, without having to introduce the "dummy type coersion functions"?
Here is my development:
Definition f1 (pad n:nat) : n = 0 -> t nat 0 -> t nat ((S pad)*n).
  intros. subst. rewrite mult_0_r. auto. Qed.
Definition f2 (pad n n':nat) : n = S n' -> t nat (S pad + (S pad * n')) -> t nat ((S pad)*n).
  intros H H0. replace (S pad + S pad * n') with (S pad * S n') in H0 by ring.
  subst; auto.
Qed.
Definition TestERR (n pad:nat) (v:Vector.t nat n) : Vector.t nat ((S pad)*n) :=
  match n as m return n=m -> Vector.t nat ((S pad)*n) with
    | 0 => fun H => f1 _ _ H (Vector.nil nat)
    | S p => fun H => f2 _ _ _ H (append (const 0 (S pad)) (const 0 ((S pad)*p)))
  end
    (eq_refl n).
