- Cc: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Strange obligations in Coq proof on vectors
- Date: Wed, 6 May 2015 12:24:57 +0200
As the others' have said, it seems to be a problem with "Program".
I tried to rewrite TestERR without using Program.
I use the "Convoy Pattern" idea to not lose the info that n=0 in the first case and n=S n' in the second case.
I had to convince the type checker that
* when n=0 then t nat 0 actually is equal t nat ((S pad)*n, and
* when n=S n' then t nat (S pad + (S pad * n')) -> t nat ((S pad)*n)
To do that, I defined two functions, f1 and f2 that took a term of the first type and returned the second type.
My question is: is there a more elegant way to do this, without having to introduce the "dummy type coersion functions"?
Here is my development:
Definition f1 (pad n:nat) : n = 0 -> t nat 0 -> t nat ((S pad)*n).intros. subst. rewrite mult_0_r. auto. Qed.Definition f2 (pad n n':nat) : n = S n' -> t nat (S pad + (S pad * n')) -> t nat ((S pad)*n).intros H H0. replace (S pad + S pad * n') with (S pad * S n') in H0 by ring.subst; auto.Qed.Definition TestERR (n pad:nat) (v:Vector.t nat n) : Vector.t nat ((S pad)*n) :=match n as m return n=m -> Vector.t nat ((S pad)*n) with| 0 => fun H => f1 _ _ H (Vector.nil nat)| S p => fun H => f2 _ _ _ H (append (const 0 (S pad)) (const 0 ((S pad)*p)))end(eq_refl n).
On Wed, May 6, 2015 at 8:00 AM, Vadim Zaliva <vzaliva AT cmu.edu> wrote:
Hi!
Consider this simple definition:
Require Import Coq.Vectors.Vector.
Require Import Omega.
Require Import ArithRing.
Program Definition TestOK (n pad:nat) (v:Vector.t nat n) : Vector.t nat ((S pad)*n) :=
match n with
| 0 => Vector.nil nat
| S p => const 0 ((S pad) + ((S pad)*p))
end.
Next Obligation.
ring.
Defined.
Now, I am replacing const in S p case with equivalent concatenation of two consts:
Program Definition TestERR (n pad:nat) (v:Vector.t nat n) : Vector.t nat ((S pad)*n) :=
match n with
| 0 => Vector.nil nat
| S p => append (const 0 (S pad)) (const 0 ((S pad)*p))
end.
Next Obligation.
It now asks me to prove an obligation:
S pad = S p
Which does not make sense! A quick check of types shows that they indeed match:
Variable p pad : nat.
Check const 0 ((S pad) + ((S pad)*p)).
Check append (const 0 (S pad)) (const 0 ((S pad)*p)).
This is an artificial example which shows simplified case of a problem I am facing as a part of a more complex proof. I am looking for any explanations on why this is happening and how this could be avoided. Thanks!
Sincerely,
Vadim
- [Coq-Club] Strange obligations in Coq proof on vectors, Vadim Zaliva, 05/06/2015
- Re: [Coq-Club] Strange obligations in Coq proof on vectors, James Wilcox, 05/06/2015
- Re: [Coq-Club] Strange obligations in Coq proof on vectors, Guillaume Melquiond, 05/06/2015
- Re: [Coq-Club] Strange obligations in Coq proof on vectors, Lars Rasmusson, 05/06/2015
