- To: coq-club AT inria.fr
- Subject: [Coq-Club] Sums over finite sets: Dependent type error
- Date: Tue, 12 May 2015 22:24:49 -0400
I'm working on defining sums over finite sets. Sparing the details, it goes like this
Variable T : finType.
Definition foldmap
{U:Type} (f: U -> U -> U) (g: T-> U) (start: U) (A: {set T}) : U.
Definition sums
(A: {set T}) (g: T -> nat) : nat :=
foldmap (fun a b => a + b) g 0 A.
Lemma sum0:
forall g, sums set0 g = 0.
Proof.
intro g. unfold sums. unfold foldmap.
At this point, the goal looks like (basically, foldmap is defined by recursing on the cardinality of A; here choosing' H gives { x:T | x \in A /\ n = #|A :\ x| /\...})
g : T -> nat
nat_rect (fun n : nat => forall A : {set T}, n = #|A| -> nat)
(fun (A' : {set T}) (_ : 0 = #|A'|) => 0)
(fun (n : nat) (IHn : forall A : {set T}, n = #|A| -> nat)
(A : {set T}) (H : S n = #|A|) =>
let (x, H0) := choosing' H in
match H0 with
| conj _ (conj H3 (conj _ _)) => IHn (A :\ x) H3 + g x
end) #|set0| set0 eq_refl = 0
I can't make progress beyond this point because #|set0| seems inaccessible. (I want it to be 0 to simplify the nat_rect.) If I try
rewrite cards0. (*cards0
: forall T : finType, #|set0| = 0*)
I get the error
Dependent type error in rewrite of (fun _pattern_value_ : nat =>
nat_rect
(fun n : nat =>
forall A : {set T},
n = #|A| -> nat)
(fun (A' : {set T})
(fun (n : nat)
(IHn :
forall A : {set T},
n = #|A| -> nat)
(A : {set T})
(H : S n = #|A|) =>
match H0 with
| conj _
end) _pattern_value_ set0
eq_refl = 0)
and if I try to put cards0 as a hypothesis first:
pose (cards0 T) as H.
intro g. unfold sums. unfold foldmap. rewrite -> H.
I get
Error: Abstracting over the term "#|set0|" leads to a term
"fun n : nat =>
nat_rect (fun n0 : nat => forall A : {set T}, n0 = #|A| -> nat)
(fun (n0 : nat) (IHn : forall A : {set T}, n0 = #|A| -> nat)
(A : {set T}) (H : S n0 = #|A|) =>
match H0 with
end) n set0 eq_refl = 0" which is ill-typed.
What gives?
Thanks,
Holden
- [Coq-Club] Sums over finite sets: Dependent type error, Holden Lee, 05/13/2015
- Re: [Coq-Club] Sums over finite sets: Dependent type error, Jason Gross, 05/13/2015
- Re: [Coq-Club] Sums over finite sets: Dependent type error, Pierre-Yves Strub, 05/13/2015
- Re: [Coq-Club] Sums over finite sets: Dependent type error, Holden Lee, 05/13/2015
- Re: [Coq-Club] Sums over finite sets: Dependent type error, Cedric Auger, 05/13/2015
