- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Sums over finite sets: Dependent type error
- Date: Wed, 13 May 2015 08:07:02 -0400
Thanks, I will use bigop.
Still, I'd like to understand the error. How would I "generalize" over eq_refl? Here eq_refl should be of type #|set0|=#|set0|. How can I tell Coq that the type 0=#|set0| is the same as #|set0|=#|set0|, if not using rewrite?
Thanks,
Holden
On Wed, May 13, 2015 at 5:27 AM, Pierre-Yves Strub <pierre-yves AT strub.nu> wrote:
Also, I don't know how you defined foldmap, but I bet that you're folding on the size of the set, picking one element at each iteration.As a general remark, folding over the (list) enumeration of the set (or over the enumeration of the finType, filtering by membership) seems much more practical.2015-05-13 11:22 GMT+02:00 Pierre-Yves Strub <pierre-yves AT strub.nu>:Hi,Why not using bigops ? For instance, you have:big_set0: forall (R : Type) (idx : R) (op : law idx) (I : finType) (F : I -> R),\big[op/idx]_(i in set0) F i = idxBest,-- Pierre-Yves.2015-05-13 4:24 GMT+02:00 Holden Lee <holdenlee AT alum.mit.edu>:I'm working on defining sums over finite sets. Sparing the details, it goes like thisVariable T : finType.Definition foldmap{U:Type} (f: U -> U -> U) (g: T-> U) (start: U) (A: {set T}) : U....Definition sums(A: {set T}) (g: T -> nat) : nat :=foldmap (fun a b => a + b) g 0 A.Lemma sum0:forall g, sums set0 g = 0.Proof.intro g. unfold sums. unfold foldmap.At this point, the goal looks like (basically, foldmap is defined by recursing on the cardinality of A; here choosing' H gives { x:T | x \in A /\ n = #|A :\ x| /\...})g : T -> nat============================nat_rect (fun n : nat => forall A : {set T}, n = #|A| -> nat)(fun (A' : {set T}) (_ : 0 = #|A'|) => 0)(fun (n : nat) (IHn : forall A : {set T}, n = #|A| -> nat)(A : {set T}) (H : S n = #|A|) =>let (x, H0) := choosing' H inmatch H0 with| conj _ (conj H3 (conj _ _)) => IHn (A :\ x) H3 + g xend) #|set0| set0 eq_refl = 0I can't make progress beyond this point because #|set0| seems inaccessible. (I want it to be 0 to simplify the nat_rect.) If I tryrewrite cards0. (*cards0: forall T : finType, #|set0| = 0*)I get the errorDependent type error in rewrite of (fun _pattern_value_ : nat =>nat_rect(fun n : nat =>forall A : {set T},n = #|A| -> nat)(fun (A' : {set T})(_ : 0 = #|A'|) => 0)(fun (n : nat)(IHn :forall A : {set T},n = #|A| -> nat)(A : {set T})(H : S n = #|A|) =>let (x, H0) := choosing' H inmatch H0 with| conj _(conj H3 (conj _ _)) =>IHn (A :\ x) H3 + g xend) _pattern_value_ set0eq_refl = 0)and if I try to put cards0 as a hypothesis first:pose (cards0 T) as H.intro g. unfold sums. unfold foldmap. rewrite -> H.I getError: Abstracting over the term "#|set0|" leads to a term"fun n : nat =>nat_rect (fun n0 : nat => forall A : {set T}, n0 = #|A| -> nat)(fun (A' : {set T}) (_ : 0 = #|A'|) => 0)(fun (n0 : nat) (IHn : forall A : {set T}, n0 = #|A| -> nat)(A : {set T}) (H : S n0 = #|A|) =>let (x, H0) := choosing' H inmatch H0 with| conj _ (conj H3 (conj _ _)) => IHn (A :\ x) H3 + g xend) n set0 eq_refl = 0" which is ill-typed.What gives?Thanks,Holden
- [Coq-Club] Sums over finite sets: Dependent type error, Holden Lee, 05/13/2015
- Re: [Coq-Club] Sums over finite sets: Dependent type error, Jason Gross, 05/13/2015
- Re: [Coq-Club] Sums over finite sets: Dependent type error, Pierre-Yves Strub, 05/13/2015
- Re: [Coq-Club] Sums over finite sets: Dependent type error, Holden Lee, 05/13/2015
- Re: [Coq-Club] Sums over finite sets: Dependent type error, Cedric Auger, 05/13/2015
