coq-club - Re: [Coq-Club] Sums over finite sets: Dependent type error
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Sums over finite sets: Dependent type error
  • Date: Wed, 13 May 2015 11:27:41 +0200
Also, I don't know how you defined foldmap, but I bet that you're folding on the size of the set, picking one element at each iteration.
As a general remark, folding over the (list) enumeration of the set (or over the enumeration of the finType, filtering by membership) seems much more practical.
2015-05-13 11:22 GMT+02:00 Pierre-Yves Strub <pierre-yves AT strub.nu>:
Hi,
Why not using bigops ? For instance, you have:
big_set0
     : forall (R : Type) (idx : R) (op : law idx) (I : finType) (F : I -> R),
       \big[op/idx]_(i in set0) F i = idx
Best,
-- Pierre-Yves.
2015-05-13 4:24 GMT+02:00 Holden Lee <holdenlee AT alum.mit.edu>:
I'm working on defining sums over finite sets. Sparing the details, it goes like this
Variable T : finType.
Definition foldmap
  {U:Type} (f: U -> U -> U) (g: T-> U) (start: U) (A: {set T}) : U.
Definition sums
  (A: {set T}) (g: T -> nat) : nat :=
  foldmap (fun a b => a + b) g 0 A.
Lemma sum0:
  forall g, sums set0 g = 0.
Proof.
  intro g. unfold sums. unfold foldmap
At this point, the goal looks like (basically, foldmap is defined by recursing on the cardinality of A; here choosing' H gives { x:T | x \in A /\ n = #|A :\ x| /\...})
g : T -> nat
   nat_rect (fun n : nat => forall A : {set T}, n = #|A| -> nat)
     (fun (A' : {set T}) (_ : 0 = #|A'|) => 0)
     (fun (n : nat) (IHn : forall A : {set T}, n = #|A| -> nat)
        (A : {set T}) (H : S n = #|A|) =>
      let (x, H0) := choosing' H in
      match H0 with
      | conj _ (conj H3 (conj _ _)) => IHn (A :\ x) H3 + g x
      end) #|set0| set0 eq_refl = 0
I can't make progress beyond this point because #|set0| seems inaccessible. (I want it to be 0 to simplify the nat_rect.) If I try
rewrite cards0. (*cards0
     : forall T : finType, #|set0| = 0*)
I get the error
Dependent type error in rewrite of (fun _pattern_value_ : nat =>
                                           nat_rect
                                             (fun n : nat =>
                                              forall A : {set T},
                                              n = #|A| -> nat)
                                             (fun (A' : {set T})
                                             (fun (n : nat)
                                                (IHn :
                                                 forall A : {set T},
                                                 n = #|A| -> nat)
                                                (A : {set T})
                                                (H : S n = #|A|) =>
                                              match H0 with
                                              | conj _
                                              end) _pattern_value_ set0
                                             eq_refl = 0)
and if I try to put cards0 as a hypothesis first:
pose (cards0 T) as H.
  intro g. unfold sums. unfold foldmap. rewrite -> H.
I get
Error: Abstracting over the term "#|set0|" leads to a term
"fun n : nat =>
 nat_rect (fun n0 : nat => forall A : {set T}, n0 = #|A| -> nat)
   (fun (n0 : nat) (IHn : forall A : {set T}, n0 = #|A| -> nat)
      (A : {set T}) (H : S n0 = #|A|) =>
    match H0 with
    end) n set0 eq_refl = 0" which is ill-typed.
What gives?
Thanks,
Holden
