- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Sums over finite sets: Dependent type error
- Date: Tue, 12 May 2015 23:36:52 -0400
Try generalizing your [eq_refl] proof before rewriting. Once you rewrite, [eq_refl] no longer proves the equality you want it to.
-Jason
On May 12, 2015 10:26 PM, "Holden Lee" <holdenlee AT alum.mit.edu> wrote:
I'm working on defining sums over finite sets. Sparing the details, it goes like thisVariable T : finType.Definition foldmap{U:Type} (f: U -> U -> U) (g: T-> U) (start: U) (A: {set T}) : U....Definition sums(A: {set T}) (g: T -> nat) : nat :=foldmap (fun a b => a + b) g 0 A.Lemma sum0:forall g, sums set0 g = 0.Proof.intro g. unfold sums. unfold foldmap.At this point, the goal looks like (basically, foldmap is defined by recursing on the cardinality of A; here choosing' H gives { x:T | x \in A /\ n = #|A :\ x| /\...})g : T -> nat============================nat_rect (fun n : nat => forall A : {set T}, n = #|A| -> nat)(fun (A' : {set T}) (_ : 0 = #|A'|) => 0)(fun (n : nat) (IHn : forall A : {set T}, n = #|A| -> nat)(A : {set T}) (H : S n = #|A|) =>let (x, H0) := choosing' H inmatch H0 with| conj _ (conj H3 (conj _ _)) => IHn (A :\ x) H3 + g xend) #|set0| set0 eq_refl = 0I can't make progress beyond this point because #|set0| seems inaccessible. (I want it to be 0 to simplify the nat_rect.) If I tryrewrite cards0. (*cards0: forall T : finType, #|set0| = 0*)I get the errorDependent type error in rewrite of (fun _pattern_value_ : nat =>nat_rect(fun n : nat =>forall A : {set T},n = #|A| -> nat)(fun (A' : {set T})(_ : 0 = #|A'|) => 0)(fun (n : nat)(IHn :forall A : {set T},n = #|A| -> nat)(A : {set T})(H : S n = #|A|) =>let (x, H0) := choosing' H inmatch H0 with| conj _(conj H3 (conj _ _)) =>IHn (A :\ x) H3 + g xend) _pattern_value_ set0eq_refl = 0)and if I try to put cards0 as a hypothesis first:pose (cards0 T) as H.intro g. unfold sums. unfold foldmap. rewrite -> H.I getError: Abstracting over the term "#|set0|" leads to a term"fun n : nat =>nat_rect (fun n0 : nat => forall A : {set T}, n0 = #|A| -> nat)(fun (A' : {set T}) (_ : 0 = #|A'|) => 0)(fun (n0 : nat) (IHn : forall A : {set T}, n0 = #|A| -> nat)(A : {set T}) (H : S n0 = #|A|) =>let (x, H0) := choosing' H inmatch H0 with| conj _ (conj H3 (conj _ _)) => IHn (A :\ x) H3 + g xend) n set0 eq_refl = 0" which is ill-typed.What gives?Thanks,Holden
- [Coq-Club] Sums over finite sets: Dependent type error, Holden Lee, 05/13/2015
- Re: [Coq-Club] Sums over finite sets: Dependent type error, Jason Gross, 05/13/2015
- Re: [Coq-Club] Sums over finite sets: Dependent type error, Pierre-Yves Strub, 05/13/2015
- Re: [Coq-Club] Sums over finite sets: Dependent type error, Holden Lee, 05/13/2015
- Re: [Coq-Club] Sums over finite sets: Dependent type error, Cedric Auger, 05/13/2015
