coq-club - Re: [Coq-Club] monotonicity of hints for auto?
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] monotonicity of hints for auto?
  • Date: Thu, 21 May 2015 15:38:51 -0400
On 05/21/2015 03:03 PM, Jason Gross wrote:
[auto] does not backtrack across solved goals. Here is what's going on:*
When [le_n] has a lower cost than [le_S], it gets run immediately on the
left goal. [1 <= 0] is not solvable, so [auto] as a whole fails.
When [le_S] gets run before [le_n], [auto] will eat its stack trying to
apply [le_S], notice, when its stack is gone, that the goal is not solved,
backtrack to the next hint at the bottom, and apply [le_S]. So then the
right side is provable, because it's [1 <= 3] if you use [auto with nocore
mydb], or [1 <= 8] if you use [auto 10 with nocore mydb].
Here's what I ran:
Require Import Coq.Strings.String.
Ltac idtac_goal n :=
match goal with |- ?G => idtac n G end;
try match goal with H := ?T |- _ => idtac T end.
Hint Extern 1 (_ /\ _) => idtac_goal 0; apply conj; [ pose "left"%string |
pose "right"%string ] : mydb.
Hint Extern 1 (_ <= _) => idtac_goal 1; apply le_n : mydb.
Hint Extern 1 (_ <= _) => idtac_goal 2; apply le_S : mydb.
Hint Extern 1 (_ = _) => idtac_goal 3; reflexivity : mydb.
Goal exists x, 0<=x /\ 1<=x.
eexists.
try auto 10 with nocore mydb.
OK - the diagnosis was off, but the prognosis remains - auto isn't monotonic. And that not-backtracking-across-solved-goals issue also is a pain - or, rather, is the primary pain - because full backtracking across solved goals would imply monotonicity.
I'm considering a way around this - it would involve using Print HintDb to dump hints to a file. Then parse the file to create a new Coq script that would add the hints to a new db - but with all hints for the same head symbol ("hintlets") put into a single "+" hint, like so:
Hint Extern 1 (_ <= _) => (apply len_n + apply le_S) : newdb.
perhaps with the order of hintlets in each hint "+" tactical ordered by their original cost (or order in the original db if the same cost), with the overall hint cost being that of the lowest cost included hintlet.
I think the resulting db should fully backtrack across goals (and so also be monotonic) - at least for auto, which is currently the only automation tactic that can backtrack within a "+" tactical.
Sound promising? (If this sounds desperate that's because it is. ;)
-- Jonathan
