- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] monotonicity of hints for auto?
- Date: Thu, 21 May 2015 16:47:28 -0400
On 05/21/2015 03:38 PM, Jonathan Leivent wrote:
I'm considering a way around this - it would involve using Print HintDb to dump hints to a file. Then parse the file to create a new Coq script that would add the hints to a new db - but with all hints for the same head symbol ("hintlets") put into a single "+" hint, like so:
Hint Extern 1 (_ <= _) => (apply len_n + apply le_S) : newdb.
perhaps with the order of hintlets in each hint "+" tactical ordered by their original cost (or order in the original db if the same cost), with the overall hint cost being that of the lowest cost included hintlet.
I think the resulting db should fully backtrack across goals (and so also be monotonic) - at least for auto, which is currently the only automation tactic that can backtrack within a "+" tactical.
Sound promising? (If this sounds desperate that's because it is. ;)
-- Jonathan
First obstacle : extern hints that use pattern variables or patterns involving more constants than just the head symbol don't print out with sufficient info to be parsed and re-generated. For instance:
Hint Extern 7 (?X <> ?Y) => idtac X Y.
prints only as:
For not -> (*external*) idtac X Y(level 7, id 0)
so, the equality (non-head constant) and binding of X and Y are all lost in the printout.
But, hopefully there are not many of those kind of hints - so that rewriting them by hand won't be too hard.
-- Jonathan
- [Coq-Club] monotonicity of hints for auto?, Jonathan Leivent, 05/21/2015
- Re: [Coq-Club] monotonicity of hints for auto?, Jonathan Leivent, 05/21/2015
- Re: [Coq-Club] monotonicity of hints for auto?, Jason Gross, 05/21/2015
