coq-club - Re: [Coq-Club] monotonicity of hints for auto?
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] monotonicity of hints for auto?
  • Date: Thu, 21 May 2015 14:31:51 -0400
On 05/21/2015 12:58 PM, Jonathan Leivent wrote:
This statement appears in Adam Chlipala's CPDT, in the Proof Search by Logic Programming section:
This "non-monotonicity" of rewrite hints contrasts with the situation for auto, where new hints may slow down proof search but can never "break" old proofs.
However, this isn't the case, as illustrated here (using 8.5):
Hint Extern 1 (_ /\ _) => apply conj : mydb.
Hint Extern 1 (_ <= _) => apply le_n : mydb.
Hint Extern 1 (_ <= _) => apply le_S : mydb.
Hint Extern 1 (_ = _) => reflexivity : mydb.
Goal exists x, 0<=x /\ 1<=x.
eexists.
Fail solve [auto with mydb]. (*some hint in the core db prevents solution here*)
auto with nocore mydb.
Qed.
The question is - which should be right? Should auto (but not eauto) have the monotonicity of hints property, or not? That property would certainly be nice to have in many cases, as it would make the introduction of new hints less dangerous with respect to maintainability and modularity.
-- Jonathan
Upon examining this more closely - it looks like auto is failing to be monotonic (at least) because it isn't backtracking 0-cost hints. For instance:
eexists.
solve [auto with nocore mydb].
Undo.
Hint Extern 0 (_ <= _) => apply le_n : mydb.
Fail solve [auto with nocore mydb]. (*above 0-cost hint prevents solution*)
Abort.
Is this a bug in auto?
-- Jonathan
