- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] monotonicity of hints for auto?
- Date: Thu, 21 May 2015 14:43:25 -0400
Upon examining this more closely - it looks like auto is failing to be monotonic (at least) because it isn't backtracking 0-cost hints. For instance:
Hint Extern 1 (_ /\ _) => apply conj : mydb.
Hint Extern 1 (_ <= _) => apply le_n : mydb.
Hint Extern 1 (_ <= _) => apply le_S : mydb.
Hint Extern 1 (_ = _) => reflexivity : mydb.
Goal exists x, 0<=x /\ 1<=x.
eexists.
Fail solve [auto with mydb].
solve [auto with nocore mydb].
Undo.
Hint Extern 0 (_ <= _) => apply le_n : mydb.
Fail solve [auto with nocore mydb]. (*above 0-cost hint prevents solution*)
Abort.
Is this a bug in auto?
-- Jonathan
That's not quite right, either. The above case where all costs are increased by any N - so that the costs of the initial 4 hints are N+1 and the cost of the blocking hint is H - also fails. In other words, the non-monotonicity-inducing behavior is that auto won't backtrack a hint at cost N for a hint at cost >N.
I thought that costs were just to induce an order of proof search for performance reasons.
-- Jonathan
- [Coq-Club] monotonicity of hints for auto?, Jonathan Leivent, 05/21/2015
- Re: [Coq-Club] monotonicity of hints for auto?, Jonathan Leivent, 05/21/2015
- Re: [Coq-Club] monotonicity of hints for auto?, Jason Gross, 05/21/2015
