- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Unknown type error
- Date: Mon, 29 Jun 2015 10:34:40 -0400
It's very likely that the implicit arguments aren't the same. For instance, that (inl n) would be (@inl A n) when what's needed is an (@inl B n). Using the "Set Printing All." directive will allow you to determine what's different.
-Greg
On Mon, Jun 29, 2015 at 10:31 AM, Marcus Ramos <marcus.ramos AT univasf.edu.br> wrote:
Hi,What should I do when I get the following error message?"The term "H29" has type "In (inl n) (map inl r')"while it is expected to have type "In (inl n) (map inl r')"."I am using Coq 8.4 pl14 in CoqIDE for Windows 8.Thanks in advance,Marcus.
- [Coq-Club] Unknown type error, Marcus Ramos, 06/29/2015
- Re: [Coq-Club] Unknown type error, Greg Morrisett, 06/29/2015
- Re: [Coq-Club] Unknown type error, Pierre Courtieu, 06/29/2015
- Re: [Coq-Club] Unknown type error, Jonathan Leivent, 06/29/2015
- Re: [Coq-Club] Unknown type error, Yann Régis-Gianas, 06/29/2015
- Re: [Coq-Club] Unknown type error, Marcus Ramos, 06/29/2015
