- From: Pierre Courtieu <pierre.courtieu AT gmail.com>
- To: Coq Club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Speeding up inversion on large inductives
- Date: Thu, 10 Sep 2015 11:47:14 +0200
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=pierre.courtieu AT gmail.com; spf=Pass smtp.mailfrom=pierre.courtieu AT gmail.com; spf=None smtp.helo=postmaster AT mail-lb0-f176.google.com
- Ironport-phdr: 9a23:Ip+MhBeTgnn7RQUVOPJ1OEwelGMj4u6mDksu8pMizoh2WeGdxc69ZR7h7PlgxGXEQZ/co6odzbGG7+a5BSQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTrkbnus7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cYk7sb+sVBSaT3ebgjBfwdVWx+cjN92Mq+nh7aBSCL+3FUBm4Ri19DBxXPxBD8RJb49CXg4LlTwi6faPX3QKouVHyJ6LpxVB7llW9TLz806nvazMd3kbhHoR+8jxN6yo/QJoqSMawtLevmYdoGSD8ZDY5qXCtbD9b5NtNXAg==
Hi Michael, I am not sure why -dont-load-proof is slow, but keep in mind that:
1) the statement itself is rather big, and the file is probably
*huge*, even without loading proofs, in may take a while to parse,
even partially, because of its size.
2) "Derive Inversion foo with bar." Does not give a clue on the type
of the generated principle foo. Only after type-checking the generated
term do we know its type. This explains why the v8.5 "lazy"
computation of proofs does not work in this case: the strategy
consisting in only reading the statement and postponing the proofs
cannot be used there: there is no statement. Hence the hackish
copy-paste of the statements as axioms so that the depedency with the
file containing the Derive Inversion is forgotten.
P.
2015-09-10 11:19 GMT+02:00 Soegtrop, Michael
<michael.soegtrop AT intel.com>:
> Dear Coq Users,
> I was following this discussion and I think there is one implied question
> in the original post which hasn't been answered as yet: Petar wrote that he
> used coqc with -dont-load-proofs and it still made a speed difference
> between defining the inversions rules as axioms and deriving them. I
> thought that the difference between ending a proof with Qed and Defined is
> that in the first case the proof term remains opaque and only the
> information that the proof exists may be used in further steps, but not the
> proof term as such. So I don't understand why the speed difference between
> axioms and opaque proofs exists and would very much appreciate if someone
> could explain why this is.
> In Coq 8.5 I got the impression that proof terms are not loaded unless
> really used e.g. in a Print. A Print of an imported proof results in a
> message that an opaque proof term has been loaded from a library. Also the
> background proof mechanism of CoqIDE makes the user believe that Coq 8.5
> can handle opaque proofs.
> Finally I wonder what effect it would have to put the proofs into a module
> and then remove the proof terms by opaque signature ascription. In my
> experience this makes the proofs more opaque than Qed does, e.g. they are
> no longer accessible to Print. Would it still be required to load the proof
> terms when such an opaque module is loaded from a library?
> Best regards,
> Michael
> Intel Deutschland GmbH
> Registered Address: Am Campeon 10-12, 85579 Neubiberg, Germany
> Tel: +49 89 99 8853-0, www.intel.de
> Managing Directors: Christin Eisenschmid, Prof. Dr. Hermann Eul
> Chairperson of the Supervisory Board: Tiffany Doon Silva
> Registered Office: Munich
> Commercial Register: Amtsgericht Muenchen HRB 186928
- [Coq-Club] Speeding up inversion on large inductives, Petar Maksimovic, 09/07/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Cedric Auger, 09/08/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Xavier Leroy, 09/09/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Petar Maksimovic, 09/09/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Jean-Francois Monin, 09/09/2015
- RE: [Coq-Club] Speeding up inversion on large inductives, Soegtrop, Michael, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Pierre Courtieu, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Petar Maksimovic, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Enrico Tassi, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Robbert Krebbers, 09/09/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Thomas Braibant, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Jean-Francois Monin, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Petar Maksimovic, 09/11/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Alan Schmitt, 09/15/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Vladimir Voevodsky, 09/09/2015
