- From: Thomas Braibant <thomas.braibant AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] Speeding up inversion on large inductives
- Date: Thu, 10 Sep 2015 22:21:23 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=thomas.braibant AT gmail.com; spf=Pass smtp.mailfrom=thomas.braibant AT gmail.com; spf=None smtp.helo=postmaster AT mail-ob0-f180.google.com
- Ironport-phdr: 9a23:VcgTBhXX1B1H+YKEABy96Oac23vV8LGtZVwlr6E/grcLSJyIuqrYZhGAt8tkgFKBZ4jH8fUM07OQ6PC8HzVeqs/d4TgrS99laVwssY0uhQsuAcqIWwXQDcXBSGgEJvlET0Jv5HqhMEJYS47UblzWpWCuv3ZJQk2sfTR8Kum9IIPOlcP/j7n0oM2PJVwWz2PhMPtbF1afk0b4joEum4xsK6I8mFPig0BjXKBo/15uPk+ZhB3m5829r9ZJ+iVUvO89pYYbCf2pN/dwcbsNBzM/dmsx+cej4RLEVE6E4mYWemQQiBtBRQbfukLURJD05xf6se90w2GwJ8T3R7kyRXz286dsTRbzzi0dPj8z+WfLosN1haNf5hmmokoskMbvfIiJOa8mLevmdtQASD8ZUw==
The plugin has not been maintained too much. However, if your inductive falls into the scope of what it can handle [1], you should get a much faster/smaller inversion principle out of the box.
[1] That is, it does not support completely type families with dependent types.
On Wed, Sep 9, 2015 at 6:09 PM, Robbert Krebbers <mailinglists AT robbertkrebbers.nl> wrote:
Pierre Boutillier and Thomas Braibant developed a plugin to automate Monin's approach. See:
https://github.com/braibant/invert
I do not know whether there is a newer (and maintained) version.
On 09/09/2015 04:57 PM, Petar Maksimovic wrote:
Hi Xavier - that's a good idea, and I have already tried to adapt the
work of Monin and Shi, but I was unable to automate the generation of
their principles, and writing them by hand for each of the
constructors wasn't an option.
Cheers,
Petar
On 9 September 2015 at 16:46, Xavier Leroy <xavier.leroy AT inria.fr> wrote:
2015-09-07 16:58 GMT+02:00 Petar Maksimovic <petar.maksimovic AT gmail.com
<mailto:petar.maksimovic AT gmail.com>>:
Hello everyone,
I'm working on a development where there's an inductive type with 400+
constructors. Recently, it has become necessary to invert on it
regularly, and this takes an exceedingly long time.
You might be interested in the work of Monin and Shi on "small inversions":
http://www-verimag.imag.fr/~monin/Proof/SmallInvScalesUp/paper.pdf
I'm not sure their approach solves your problems, but it could help.
On 08/09/2015 09:43, Cedric Auger wrote:
I am curious of what would lead to such a big inductive type.
One example: full modeling of the instruction set of a modern processor
architecture. ARMv7 has 413 instructions, and don't get me
started about ARMv8...
- Xavier Leroy
- Re: [Coq-Club] Speeding up inversion on large inductives, (continued)
- Re: [Coq-Club] Speeding up inversion on large inductives, Xavier Leroy, 09/09/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Petar Maksimovic, 09/09/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Jean-Francois Monin, 09/09/2015
- RE: [Coq-Club] Speeding up inversion on large inductives, Soegtrop, Michael, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Pierre Courtieu, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Petar Maksimovic, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Enrico Tassi, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Robbert Krebbers, 09/09/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Thomas Braibant, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Jean-Francois Monin, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Petar Maksimovic, 09/11/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Alan Schmitt, 09/15/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Vladimir Voevodsky, 09/09/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Cedric Auger, 09/09/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Pierre Courtieu, 09/09/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Clément Pit--Claudel, 09/09/2015
