- From: Petar Maksimovic <petar.maksimovic AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Speeding up inversion on large inductives
- Date: Fri, 11 Sep 2015 19:28:32 +0200
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=petar.maksimovic AT gmail.com; spf=Pass smtp.mailfrom=petar.maksimovic AT gmail.com; spf=None smtp.helo=postmaster AT mail-wi0-f175.google.com
- Ironport-phdr: 9a23:eOxa0hSXz3IILm1L7caF20bEsNpsv+yvbD5Q0YIujvd0So/mwa64YByN2/xhgRfzUJnB7Loc0qyN4/ymADxLuM/R+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8GVOlUD3WPtKZpJbzyI7izp/vEMhoVjLqtjgjDomVBvP9ps+GVzOFiIlAz97MrjtLRq8iBXpu5zv5UYCfayLOwESulTCy1jOGQo7uXqswPCRE2B/CgySGITxyJFHwHfpDTzXYzwtyzkt+E1jDGXIcTsC7U9Wi+j6qB1SRTAhyIONjp/+2bS3J8jxJlHqQ6s8kQsi7XfZ5uYYaJz
I am trying to get the plugin running, but I'm experiencing various
difficulties. How exactly am I supposed to use it?
Cheers,
Petar
On 10 September 2015 at 23:46, Jean-Francois Monin
<jean-francois.monin AT imag.fr>
wrote:
> As far as I can see on
> https://github.com/jscert/jscert/blob/master/coq/JsPrettyRules.v
> there is nothing complicated.
> Clauses look like:
> Inductive red_stat : state -> execution_ctx -> ext_stat -> out -> Prop :=
> | red_stat_while_2_true : forall S0 S C labs e1 t2 rv o1 o,
> red_stat S C t2 o1 ->
> red_stat S C (stat_while_3 labs e1 t2 rv o1) o ->
> red_stat S0 C (stat_while_2 labs e1 t2 rv (vret S true)) o
> JF
> On Thu, Sep 10, 2015 at 10:21:23PM +0200, Thomas Braibant wrote:
>> The plugin has not been maintained too much. However, if your inductive
>> falls into the scope of what it can handle [1], you should get a much
>> faster/smaller inversion principle out of the box.
>> [1] That is, it does not support completely type families with dependent
>> types.
>> On Wed, Sep 9, 2015 at 6:09 PM, Robbert Krebbers
>> <[1]mailinglists AT robbertkrebbers.nl>
>> wrote:
>> Pierre Boutillier and Thomas Braibant developed a plugin to automate
>> Monin's approach. See:
>> [2]https://github.com/braibant/invert
>> I do not know whether there is a newer (and maintained) version.
>> On 09/09/2015 04:57 PM, Petar Maksimovic wrote:
>> Hi Xavier - that's a good idea, and I have already tried to adapt
>> the
>> work of Monin and Shi, but I was unable to automate the generation
>> of
>> their principles, and writing them by hand for each of the
>> constructors wasn't an option.
>> Cheers,
>> Petar
>> On 9 September 2015 at 16:46, Xavier Leroy
>> <[3]xavier.leroy AT inria.fr>
>> wrote:
>> 2015-09-07 16:58 GMT+02:00 Petar Maksimovic
>> <[4]petar.maksimovic AT gmail.com
>> <mailto:[5]petar.maksimovic AT gmail.com>>:
>> Hello everyone,
>> I'm working on a development where there's an inductive
>> type
>> with 400+
>> constructors. Recently, it has become necessary to invert
>> on
>> it
>> regularly, and this takes an exceedingly long time.
>> You might be interested in the work of Monin and Shi on "small
>> inversions":
>> [6]http://www-verimag.imag.fr/~monin/Proof/SmallInvScalesUp/paper.pdf
>> I'm not sure their approach solves your problems, but it could
>> help.
>> On 08/09/2015 09:43, Cedric Auger wrote:
>> I am curious of what would lead to such a big inductive type.
>> One example: full modeling of the instruction set of a modern
>> processor
>> architecture. ARMv7 has 413 instructions, and don't get me
>> started about ARMv8...
>> - Xavier Leroy
- Re: [Coq-Club] Speeding up inversion on large inductives, (continued)
- Re: [Coq-Club] Speeding up inversion on large inductives, Jean-Francois Monin, 09/09/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Petar Maksimovic, 09/09/2015
- RE: [Coq-Club] Speeding up inversion on large inductives, Soegtrop, Michael, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Pierre Courtieu, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Petar Maksimovic, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Enrico Tassi, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Thomas Braibant, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Jean-Francois Monin, 09/10/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Petar Maksimovic, 09/11/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Alan Schmitt, 09/15/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Cedric Auger, 09/09/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Pierre Courtieu, 09/09/2015
- Re: [Coq-Club] Speeding up inversion on large inductives, Clément Pit--Claudel, 09/09/2015
