coq-club - Re: [Coq-Club] Speeding up inversion on large inductives
  • From: Jean-Francois Monin <jean-francois.monin AT imag.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Speeding up inversion on large inductives
  • Date: Thu, 10 Sep 2015 23:46:16 +0200
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jean-francois.monin AT imag.fr; spf=Neutral smtp.mailfrom=jean-francois.monin AT imag.fr; spf=None smtp.helo=postmaster AT amazone.ujf-grenoble.fr
  • Ironport-phdr: 9a23:uy3Ixh+cBEVmUP9uRHKM819IXTAuvvDOBiVQ1KB91uocTK2v8tzYMVDF4r011RmSDdmdsq0P07aempujcFJDyK7JiGoFfp1IWk1NouQttCtkPvS4D1bmJuXhdS0wEZcKflZk+3amLRodQ56mNBXsq3G/pQQfBg/4fVIsYL+lRsiL0I/vi6ibwN76XUZhvHKFe7R8LRG7/036l/I9ps9cEJs30QbDuXBSeu5blitCLFOXmAvgtI/rpMYwu3cYh/V0/MlZFK7+Yq4QTLpCDT1gPXpmytfssEzhQAKJo1UGW2MdlRtTSy3C6hD8FsPzvyL88+Rn0S+ROsztC7UzXzWkx6ZuQRCuhj1RZG1xy33elsEl1PETmxmmvREqm4M=
As far as I can see on
https://github.com/jscert/jscert/blob/master/coq/JsPrettyRules.v
there is nothing complicated.
Clauses look like:
Inductive red_stat : state -> execution_ctx -> ext_stat -> out -> Prop :=
| red_stat_while_2_true : forall S0 S C labs e1 t2 rv o1 o,
red_stat S C t2 o1 ->
red_stat S C (stat_while_3 labs e1 t2 rv o1) o ->
red_stat S0 C (stat_while_2 labs e1 t2 rv (vret S true)) o
JF
On Thu, Sep 10, 2015 at 10:21:23PM +0200, Thomas Braibant wrote:
> The plugin has not been maintained too much. However, if your inductive
> falls into the scope of what it can handle [1], you should get a much
> faster/smaller inversion principle out of the box.
> [1] That is, it does not support completely type families with dependent
> types.
> On Wed, Sep 9, 2015 at 6:09 PM, Robbert Krebbers
> <[1]mailinglists AT robbertkrebbers.nl>
> wrote:
> Pierre Boutillier and Thomas Braibant developed a plugin to automate
> Monin's approach. See:
>   [2]https://github.com/braibant/invert
> I do not know whether there is a newer (and maintained) version.
> On 09/09/2015 04:57 PM, Petar Maksimovic wrote:
> Hi Xavier - that's a good idea, and I have already tried to adapt the
> work of Monin and Shi, but I was unable to automate the generation of
> their principles, and writing them by hand for each of the
> constructors wasn't an option.
> Cheers,
> Petar
> On 9 September 2015 at 16:46, Xavier Leroy
> <[3]xavier.leroy AT inria.fr>
> wrote:
> 2015-09-07 16:58 GMT+02:00 Petar Maksimovic
> <[4]petar.maksimovic AT gmail.com
> <mailto:[5]petar.maksimovic AT gmail.com>>:
>      Hello everyone,
>      I'm working on a development where there's an inductive type
> with 400+
>      constructors. Recently, it has become necessary to invert on
> it
>      regularly, and this takes an exceedingly long time.
> You might be interested in the work of Monin and Shi on "small
> inversions":
> [6]http://www-verimag.imag.fr/~monin/Proof/SmallInvScalesUp/paper.pdf
> I'm not sure their approach solves your problems, but it could
> help.
> On 08/09/2015 09:43, Cedric Auger wrote:
> I am curious of what would lead to such a big inductive type.
> One example: full modeling of the instruction set of a modern
> processor
> architecture.  ARMv7 has 413 instructions, and don't get me
> started about ARMv8...
> - Xavier Leroy
