- To: coq-club AT inria.fr
- Subject: [Coq-Club] Doubt about refine
- Date: Sun, 7 Feb 2016 00:22:28 -0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=saulo2 AT gmail.com; spf=Pass smtp.mailfrom=saulo2 AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f41.google.com
- Ironport-phdr: 9a23:OLTtWxQeGoN9aFgEhtz+ZB9EI9psv+yvbD5Q0YIujvd0So/mwa64ZxCN2/xhgRfzUJnB7Loc0qyN4/+mAzBLu8/b+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8KVOVkD3mPnKZpJbzyI7izp/vEMhoVjLqtjgjDomVBvP9ps+GVzOFiIlAz97MrjtLRq8iBXpu5zv5UYCfayLOwESulTCy1jOGQo7uXqswPCRE2B/CgySGITxyFBHgzCpDjgV4rztWOureNg3C7AFcLzRLEwHz+l6vE4G1fTlC4bOmthoynsgctqgfcDrQ==
Hi,
I have the following types:
Set Implicit Arguments.
Section Sequence.
Variable E: Set.
Inductive Sequence: nat -> Set :=
| SequenceLeaf: E -> E -> Sequence 0
| SequenceNode: forall n, Sequence n -> Sequence n -> Sequence (S n).
Inductive List: nat -> Set :=
| ListLeaf: E -> List 0
| ListNode: forall n, E -> List n -> List (S n).
End Sequence.
Inductive Digit :=
| D0
| D1.
Now I am trying to define the function:
Fixpoint get E n (t: Sequence E n) (ds: List Digit n): E.
I am able to define it using tactics:
Proof.
inversion t as [e0 e1 | x s0 s1].
destruct ds as [d | y d ds'].
destruct d.
apply e0.
apply e1.
congruence.
congruence.
inversion H.
rewrite <- H1 in ds'.
destruct d.
apply get with (n := x).
apply s0.
apply ds'.
apply s1.
apply ds'.
Defined.
Unfortunately, I am not being able to define the function using refine
Proof.
refine(
match t with
| SequenceLeaf e0 e1 =>
match ds with
| ListLeaf d =>
match d with
| D0 => e0
| D1 => e1
end
| ListNode y d ds' => _
end
| SequenceNode x s0 s1 =>
match ds with
| ListLeaf d => _
| ListNode y d ds' =>
match d with
| D0 => get E x s0 _
| D1 => get E x s1 _
end
end
end
congruence.
Defined.
Looks like refine is discarding some information that the command
inversion t as [e0 e1 | x t0 t1].
(in the tactics based definition of the function get) is preserving. Is there anything that I can do in order to refine preserve this information?
Any help will be gratefully appreciated,
Saulo
- [Coq-Club] Doubt about refine, Saulo Araujo, 02/07/2016
- Re: [Coq-Club] Doubt about refine, James Wilcox, 02/07/2016
- Re: [Coq-Club] Doubt about refine, Guillaume Melquiond, 02/07/2016
- Re: [Coq-Club] Doubt about refine, Saulo Araujo, 02/07/2016
- Re: [Coq-Club] Doubt about refine, Saulo Araujo, 02/09/2016
- Re: [Coq-Club] Doubt about refine, Cedric Auger, 02/10/2016
- Re: [Coq-Club] Doubt about refine, Saulo Araujo, 02/10/2016
- Re: [Coq-Club] Doubt about refine, Jonathan Leivent, 02/11/2016
- Re: [Coq-Club] Doubt about refine, Saulo Araujo, 02/11/2016
