coq-club - Re: [Coq-Club] Doubt about refine
  • From: Guillaume Melquiond <guillaume.melquiond AT inria.fr>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Doubt about refine
  • Date: Sun, 7 Feb 2016 08:26:01 +0100
On 07/02/2016 04:22, Saulo Araujo wrote:
> Looks like refine is discarding some information that the command
> *inversion t as [e0 e1 | x t0 t1].*
The refine tactic is not losing any information. It is just that the
proof term you passed to it is closer from destruct than from inversion.
And since you cannot finish this proof by starting with destruct, you
cannot expect to finish it by starting with (refine match) either.
The inversion tactic works by generalizing some equalities before doing
an actual destruct. Here you want to remember what n has become once you
have destructed (t : Sequence E n), so your proof term should start with
refine (match t in Sequence _ n' return n = n' -> _ with
| SequenceLeaf e0 e1 => _
| SequenceNode x s0 s1 => _
end eq_refl).
Notice the eq_refl at the end (the equality), and the "in Sequence _ n'
return n = n' ->" at the start (and its generzalization).
Best regards,
Guillaume
