- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Doubt about refine
- Date: Thu, 11 Feb 2016 11:12:22 -0300
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=saulo2 AT gmail.com; spf=Pass smtp.mailfrom=saulo2 AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f42.google.com
- Ironport-phdr: 9a23:dxC9EhIYX8tOizjmqtmcpTZWNBhigK39O0sv0rFitYgUKf7xwZ3uMQTl6Ol3ixeRBMOAu60C0Lad7v+ocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0ILsi6vvpNX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF6072YYVS0/iBNVAQ+NuArzQ5P26AP1s+N83G+ROsigHuN8Yiir86o+EEygsywALTNsqGw=
Hi Jonathan,
Thanks a lot for suggesting another technique. The resulting code is quite pleasant and, at least to me, has one of the best signal to noise ratio :)
I never saw the character @ used as an operator. I looked in the Coq reference manual and if, I understood it correctly, it disables the inference of implicit parameters. Could you confirm if I understood it correctly?
Sincerely,
Saulo
On Wed, Feb 10, 2016 at 9:50 PM, Jonathan Leivent <jonikelee AT gmail.com> wrote:
There is another alternative. The type indexes can be omitted in favor of extra equality fields. Doing this enables the use of basic matches in the refine, as in the following rewriting of your example. No convoy patterns are needed. I don't know why this technique isn't mentioned more frequently.
Set Implicit Arguments.
Section Sequence.
Variable E: Set.
Inductive Sequence(n : nat) : Set :=
| SequenceLeaf: E -> E -> n=0 -> Sequence n
| SequenceNode: forall m, Sequence m -> Sequence m -> n = S m -> Sequence n.
Inductive List(n : nat) : Set :=
| ListLeaf: E -> n=0 -> List n
| ListNode: forall m, E -> List m -> n = S m -> List n.
End Sequence.
Inductive Digit :=
| D0
| D1.
Fixpoint get E n (t: Sequence E n) (ds: List Digit n): E.
Proof.
refine(
match t with
| SequenceLeaf e0 e1 e =>
match ds with
| ListLeaf D0 _ => e0
| ListLeaf D1 _ => e1
| @ListNode _ _ y _ _ e2 => _
end
| @SequenceNode _ _ x s0 s1 _ =>
match ds with
| ListLeaf _ e0 => _
| @ListNode _ _ y d ds' _ =>
match d with
| D0 => get E x s0 _
| D1 => get E x s1 _
end
end
end
all:congruence.
Defined.
-- Jonathan
- [Coq-Club] Doubt about refine, Saulo Araujo, 02/07/2016
- Re: [Coq-Club] Doubt about refine, James Wilcox, 02/07/2016
- Re: [Coq-Club] Doubt about refine, Guillaume Melquiond, 02/07/2016
- Re: [Coq-Club] Doubt about refine, Saulo Araujo, 02/07/2016
- Re: [Coq-Club] Doubt about refine, Saulo Araujo, 02/09/2016
- Re: [Coq-Club] Doubt about refine, Cedric Auger, 02/10/2016
- Re: [Coq-Club] Doubt about refine, Saulo Araujo, 02/10/2016
- Re: [Coq-Club] Doubt about refine, Jonathan Leivent, 02/11/2016
- Re: [Coq-Club] Doubt about refine, Saulo Araujo, 02/11/2016
