- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] CoqIDE Crashing on Mac OS X
- Date: Mon, 8 Feb 2016 13:44:53 -0500
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=sdconsta AT syr.edu; spf=None smtp.mailfrom=sdconsta AT syr.edu; spf=None smtp.helo=postmaster AT smtp1.syr.edu
- Ironport-phdr: 9a23:5aQKLBIXyBu3A+3uVtmcpTZWNBhigK39O0sv0rFitYgUKfnxwZ3uMQTl6Ol3ixeRBMOAu60C0bqd6fGocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0ILth6voqtX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF6U7XwATi0dlRxTHwHP6ByyCoz9uSz8rfZ08DKLJ4v7Qa1iCmfq1LtiVBK90HRPDDU+6myC0sE=
Arthur,
I have also experienced this exact problem on OS X 10.11.3. But I've noticed that it only occurs when I open CoqIDE from the launchpad. If I instead invoke it from the terminal, I do not experience this issue. If you used the .dmg installer like I did, you'll either need to add <Coq install location>/Contents/MacOS/ to your $PATH variable, or soft link the coqide binary into your /usr/bin. Then from your working directory, run
$ coqide &
Best,
~Scott
On Sun, Feb 7, 2016 at 5:45 PM, Maxime Dénès <mail AT maximedenes.fr> wrote:
Hello,
An issue similar to what you describe has already been reported. We
suspect that it comes from a GTK bug under OSX but we are still
investigating.
Sorry for the inconvenience.
Maxime.
On 02/07/16 21:55, Arthur Ryman wrote:
> I am a new Coq user. I would like to use Coq to create a formal
> specification for a new language, SHACL, being developed at W3C.
> I have been experiencing intermittent crashes of CoqIDE on Mac OS X. I
> am using El Capitan 10.11.3 and CoqIDE 8.5.
> The crashes often occur when I undo proof steps.
> Is this a known problem? Is there a FAQ? Any workaround?
> I have switched to using Proof General, but I'd prefer to use CoqIDE.
> Thanks in advance for any help.
> -- Arthur Ryman
- [Coq-Club] CoqIDE Crashing on Mac OS X, Arthur Ryman, 02/07/2016
- Re: [Coq-Club] CoqIDE Crashing on Mac OS X, Maxime Dénès, 02/07/2016
- Re: [Coq-Club] CoqIDE Crashing on Mac OS X, scott constable, 02/08/2016
- Re: [Coq-Club] CoqIDE Crashing on Mac OS X, Greg Bush, 02/08/2016
- Re: [Coq-Club] CoqIDE Crashing on Mac OS X, Arthur Ryman, 02/15/2016
- Re: [Coq-Club] CoqIDE Crashing on Mac OS X, Arthur Ryman, 02/09/2016
