coq-club - Re: [Coq-Club] CoqIDE Crashing on Mac OS X
  • To: Coq Club <coq-club AT inria.fr>
  • Subject: Re: [Coq-Club] CoqIDE Crashing on Mac OS X
  • Date: Mon, 15 Feb 2016 11:42:50 -0500
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=arthur.ryman AT gmail.com; spf=Pass smtp.mailfrom=arthur.ryman AT gmail.com; spf=None smtp.helo=postmaster AT mail-ob0-f180.google.com
  • Ironport-phdr: 9a23:evW02xI8P47M3XbQatmcpTZWNBhigK39O0sv0rFitYgULf3xwZ3uMQTl6Ol3ixeRBMOAu60C17Od4viocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0ILrjqvjo9X6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD89pozcNLUL37cqIkVvQYSW1+ayFmrPHs4DLEVEOk4mYWGjEdlQMNCAzY5jn7WI3wu230rLwu9jOdOJjfV6w0RC7q1bZuQRmg3C4dKz4k6ifNm8l5iopUpRugo1p0xIuCM9LdD+Z3Yq6IJYBSfmFGRMsEEnUZWo4=
Greg,
Thx. I'll try that too.
-- Arthur
On Mon, Feb 8, 2016 at 1:54 PM, Greg Bush
<gbush AT kitchenbrains.com>
wrote:
> This work-around doesn’t seem to work for me, but I’ve still been able to
> use the 8.5 coqide after noticing that you can now edit text in the green
> regions and it will automatically undo back to this point. This type of
> undo doesn’t seem to cause the same problem.
> On Feb 8, 2016, at 1:44 PM, scott constable
> <sdconsta AT syr.edu<mailto:sdconsta AT syr.edu>>
> wrote:
> Arthur,
> I have also experienced this exact problem on OS X 10.11.3. But I've
> noticed that it only occurs when I open CoqIDE from the launchpad. If I
> instead invoke it from the terminal, I do not experience this issue. If you
> used the .dmg installer like I did, you'll either need to add <Coq install
> location>/Contents/MacOS/ to your $PATH variable, or soft link the coqide
> binary into your /usr/bin. Then from your working directory, run
> $ coqide &
> Best,
> ~Scott
> On Sun, Feb 7, 2016 at 5:45 PM, Maxime Dénès
> <mail AT maximedenes.fr<mailto:mail AT maximedenes.fr>>
> wrote:
> Hello,
> An issue similar to what you describe has already been reported. We
> suspect that it comes from a GTK bug under OSX but we are still
> investigating.
> Sorry for the inconvenience.
> Maxime.
> On 02/07/16 21:55, Arthur Ryman wrote:
>> I am a new Coq user. I would like to use Coq to create a formal
>> specification for a new language, SHACL, being developed at W3C.
>> I have been experiencing intermittent crashes of CoqIDE on Mac OS X. I
>> am using El Capitan 10.11.3 and CoqIDE 8.5.
>> The crashes often occur when I undo proof steps.
>> Is this a known problem? Is there a FAQ? Any workaround?
>> I have switched to using Proof General, but I'd prefer to use CoqIDE.
>> Thanks in advance for any help.
>> -- Arthur Ryman
