coq-club - Re: [Coq-Club] CoqIDE Crashing on Mac OS X
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] CoqIDE Crashing on Mac OS X
  • Date: Mon, 8 Feb 2016 19:52:36 -0500
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=arthur.ryman AT gmail.com; spf=Pass smtp.mailfrom=arthur.ryman AT gmail.com; spf=None smtp.helo=postmaster AT mail-io0-f171.google.com
  • Ironport-phdr: 9a23:2VaxfBC9YZ69toBHlnCWUyQJP3N1i/DPJgcQr6AfoPdwSP7+pcbcNUDSrc9gkEXOFd2CrakU1KyM4uu7BiQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTokbrjsMaMKyxzxxODIppKZC2sqgvQssREyaBDEY0WjiXzn31TZu5NznlpL1/A1zz158O34YIxu38I46FpweIbAf6/J/5wDewATWduD2dg78ry8BLHUAGn530GU2xQnAAbLRLC6UTTRIvxrzGyjPt40S/SacTsUbApQ3K4/qJiTjfnjS4GM3gy92SB2Z84t75SvB/0/083+IXTeozAZKJz
Scott,
I launch it from the dock. Thanks for the tip. I'll try it from a terminal window.
-- Arthur
On Feb 8, 2016, at 1:44 PM, scott constable <sdconsta AT syr.edu> wrote:
Arthur,
I have also experienced this exact problem on OS X 10.11.3. But I've noticed that it only occurs when I open CoqIDE from the launchpad. If I instead invoke it from the terminal, I do not experience this issue. If you used the .dmg installer like I did, you'll either need to add <Coq install location>/Contents/MacOS/ to your $PATH variable, or soft link the coqide binary into your /usr/bin. Then from your working directory, run
$ coqide &
Best,
~Scott
On Sun, Feb 7, 2016 at 5:45 PM, Maxime Dénès <mail AT maximedenes.fr> wrote:
Hello,
An issue similar to what you describe has already been reported. We
suspect that it comes from a GTK bug under OSX but we are still
investigating.
Sorry for the inconvenience.
Maxime.
On 02/07/16 21:55, Arthur Ryman wrote:
> I am a new Coq user. I would like to use Coq to create a formal
> specification for a new language, SHACL, being developed at W3C.
> I have been experiencing intermittent crashes of CoqIDE on Mac OS X. I
> am using El Capitan 10.11.3 and CoqIDE 8.5.
> The crashes often occur when I undo proof steps.
> Is this a known problem? Is there a FAQ? Any workaround?
> I have switched to using Proof General, but I'd prefer to use CoqIDE.
> Thanks in advance for any help.
> -- Arthur Ryman
