- To: "coq-club AT inria.fr" <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] CoqIDE Crashing on Mac OS X
- Date: Mon, 8 Feb 2016 18:54:05 +0000
- Accept-language: en-US
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=gbush AT kitchenbrains.com; spf=PermError smtp.mailfrom=gbush AT kitchenbrains.com; spf=None smtp.helo=postmaster AT mail.kitchenbrains.com
- Ironport-phdr: 9a23:YGhVjBKQb9bn4aAX/tmcpTZWNBhigK39O0sv0rFitYgUL/TxwZ3uMQTl6Ol3ixeRBMOAu60C0bqd6PqocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0ILth6vpodX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVG679ZuEzSaFSJDUgKWE8osPx/1GXRgyWo3AYT28+kxxSAgGD4gusDbnrtS6vmfBw12GwINb2BeQ7Uym5749oSQPjiCoBPSQw8WfMzMd3ifQI81qauxVjztuMM8muP/1kc/aFcA==
This work-around doesn’t seem to work for me, but I’ve still been able to use
the 8.5 coqide after noticing that you can now edit text in the green regions
and it will automatically undo back to this point. This type of undo doesn’t
seem to cause the same problem.
On Feb 8, 2016, at 1:44 PM, scott constable
<sdconsta AT syr.edu<mailto:sdconsta AT syr.edu>>
wrote:
Arthur,
I have also experienced this exact problem on OS X 10.11.3. But I've noticed
that it only occurs when I open CoqIDE from the launchpad. If I instead
invoke it from the terminal, I do not experience this issue. If you used the
.dmg installer like I did, you'll either need to add <Coq install
location>/Contents/MacOS/ to your $PATH variable, or soft link the coqide
binary into your /usr/bin. Then from your working directory, run
$ coqide &
Best,
~Scott
On Sun, Feb 7, 2016 at 5:45 PM, Maxime Dénès
<mail AT maximedenes.fr<mailto:mail AT maximedenes.fr>>
wrote:
Hello,
An issue similar to what you describe has already been reported. We
suspect that it comes from a GTK bug under OSX but we are still
investigating.
Sorry for the inconvenience.
Maxime.
On 02/07/16 21:55, Arthur Ryman wrote:
> I am a new Coq user. I would like to use Coq to create a formal
> specification for a new language, SHACL, being developed at W3C.
> I have been experiencing intermittent crashes of CoqIDE on Mac OS X. I
> am using El Capitan 10.11.3 and CoqIDE 8.5.
> The crashes often occur when I undo proof steps.
> Is this a known problem? Is there a FAQ? Any workaround?
> I have switched to using Proof General, but I'd prefer to use CoqIDE.
> Thanks in advance for any help.
> -- Arthur Ryman
- [Coq-Club] CoqIDE Crashing on Mac OS X, Arthur Ryman, 02/07/2016
- Re: [Coq-Club] CoqIDE Crashing on Mac OS X, Maxime Dénès, 02/07/2016
- Re: [Coq-Club] CoqIDE Crashing on Mac OS X, scott constable, 02/08/2016
- Re: [Coq-Club] CoqIDE Crashing on Mac OS X, Greg Bush, 02/08/2016
- Re: [Coq-Club] CoqIDE Crashing on Mac OS X, Arthur Ryman, 02/15/2016
- Re: [Coq-Club] CoqIDE Crashing on Mac OS X, Arthur Ryman, 02/09/2016
