- From: Clément Pit--Claudel <clement.pit AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs
- Date: Thu, 3 Mar 2016 14:26:58 -0700
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
- Ironport-phdr: 9a23:LaTi9hemLysufULKIockVqUHlGMj4u6mDksu8pMizoh2WeGdxc6+Yx7h7PlgxGXEQZ/co6odzbGG7Oa/BSdZusfJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbvipNuMP04R32v1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdfFXEtN30/zMztrxjKCwWVtVUGVWBDuR7JBgXD8CbCX4u09wD+v/dx1S3SacbyQLU5Xyjk96Z3YBDtgSYDcTU+9TeE2YRLkKtHrUf59FREyInObdTNOQ==
On 03/03/2016 02:23 PM, Ralf Jung wrote:
> All my experiments with tactics-in-terms lead to the same trouble as
> plain eq_refl: The tactic is run before the contexts are propagated
> down, so things don't work. But it may well be that I did this wrong; I
> have yet to see a successful use of tactics-in-terms ;-)
Something like this?
Definition test2 : expr nil :=
ltac:(refine (Lam _ "x" (Var _ "x" _)); apply eq_refl).
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] Trouble constructing terms of dependent types involving proofs, Ralf Jung, 03/03/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Jonathan Leivent, 03/03/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Ralf Jung, 03/03/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Clément Pit--Claudel, 03/03/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Robbert Krebbers, 03/03/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Ralf Jung, 03/04/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Gregory Malecha, 03/05/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Ralf Jung, 03/06/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Jonathan Leivent, 03/06/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Gregory Malecha, 03/07/2016
