- From: Clément Pit--Claudel <clement.pit AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs
- Date: Thu, 3 Mar 2016 15:16:25 -0700
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
- Ironport-phdr: 9a23:SCD1iBx+OO4W/RHXCy+O+j09IxM/srCxBDY+r6Qd0e4RIJqq85mqBkHD//Il1AaPBtWEra0YwLOL7+jJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6NyZvrnLnvp9X6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF6k4voZX2MKpSJJH02AxxXzQ5v8tmOuve5w3SScIYvuTKwcVjGr7qMtQxjt3nRUfwUl+X3a35QjxJlQpwis8kRy
Very nice!
On 03/03/2016 02:59 PM, Robbert Krebbers wrote:
> Using some more type class magic I managed to let a "Hint Extern" generate
> "eq_refl" proofs. It even generates sensible error messages in case you are
> using variables that are not bound.
> Require Import Decidable List String.
> Open Scope string_scope.
> Import ListNotations Sumbool.
> Definition in_dec := List.in_dec string_dec.
> Definition in_dec_bool x X := proj1_sig (bool_of_sumbool (in_dec x X)).
> Class IsIn (x : string) (X : list string) :=
> is_in : in_dec_bool x X = true.
> Hint Extern 0 (IsIn _ _) =>
> vm_compute; apply eq_refl : typeclass_instances.
> Inductive expr (X : list string) :=
> | Var (x : string) `{IsIn x X} : expr X
> | App : expr X -> expr X -> expr X
> | Lam (x : string) : expr (x :: X) -> expr X.
> Arguments Var {_} _ {_}.
> Arguments App {_} _ _.
> Arguments Lam {_} _ _.
> Coercion App : expr >-> Funclass.
> Notation "# x" := (Var x) (at level 8, format "# x").
> Notation "λ: x .. y , e" := (Lam x .. (Lam y e) ..)
> (at level 102, x, y at level 1, e at level 200).
> Definition test1 : expr nil :=
> λ: "x" "y" "z", #"z" #"x" (λ: "foo", #"foo" #"x").
> Fail Definition test2 : expr nil :=
> λ: "x" "y" "z", #"z" #"x" (λ: "q" "foo", #"foo" #"bar").
> Unable to satisfy the following constraints:
> ?H2 : "IsIn "bar" ["foo"; "q"; "z"; "y"; "x"]"
> Definition test3 : expr ["bar"] :=
> On 03/03/2016 10:30 PM, Robbert Krebbers wrote:
>> I managed to get this working with type classes, see below. Only now,
>> instead of having an eq_refl for the proof, you have something that type
>> class search generates and which can thus become rather big.
>> Implicit Type (x : string).
>> Implicit Type (X : list string).
>> Class IsIn (x : string) (X : list string) := is_in : In x X.
>> Instance is_in_here x X : IsIn x (x :: X). now left. Qed.
>> Instance is_in_further x y X : IsIn x X -> IsIn x (y :: X). now right. Qed.
>> Inductive expr X : Type :=
>> | Var x `{IsIn x X} : expr X
>> | Lam x : expr (x::X) -> expr X.
>> Lam "x" (Lam "y" (App (Var "x") (Var "y"))).
>> On 03/03/2016 09:26 PM, Ralf Jung wrote:
>>> Hi everybody,
>>> I am trying to use dependent types to represent the free variables of a
>>> deeply embedded language that uses names for binders -- and I am running
>>> into some trouble.
>>> Yeah, I know that "dependent types" and "names for binders" are asking
>>> for trouble. The point is, we actually want to be able to read the
>>> programs we are writing in that deeply embedded language, an deBruijn
>>> indices are rather cryptic. And we need to keep track of whether the
>>> terms are closed, hence the dependent types. This actually worked out
>>> much better than I anticipated, but there still is a serious problem.
>>> The concrete problem we are having is that, if we omit all the type
>>> annotations you want to omit, then Coq fails to type-check the term even
>>> though there is a pretty straight-forward well to add the missing types.
>>> For example:
>>> ------ BEGIN ------
>>> Obligation Tactic := fail.
>>> (* We don't use lists in our actual code, but that doesn't matter.
>>> What matters is that the proof obligation on variables is something
>>> that can be discharged by "eq_refl". *)
>>> | Var x : in_dec_bool x X = true -> expr X
>>> (* This works, but having to state the context in which the
>>> variable is checked is silly. *)
>>> Lam _ "x" (Var ["x"] "x" eq_refl).
>>> (* Omitting the context fails. *)
>>> Lam _ "x" (Var _ "x" eq_refl).
>>> (* With Program, it works. *)
>>> Program Definition test3 : expr nil :=
>>> --------- END --------------
>>> The comments explain the problem. The "test2" fails with:
>>>> The term "eq_refl" has type "in_dec_bool "x" ?l0 = in_dec_bool "x"
>>>> ?l0" while it is expected to have type
>>>> "in_dec_bool "x" ?l0 = true".
>>> It seems that Coq starts unifying too early or in the wrong order. If it
>>> would just propagate the X downwards, it would notice that the first "_"
>>> can only be "nil", and the second "_" can only be "[x]", and "eq_refl"
>>> actually works.
>>> Using "Program Definition", we can write this down; but this is rather
>>> annoying because Program cannot be used everywhere. Also, in the full
>>> language, we have some trouble with "Program" generating obligations to
>>> prove some equalities, even though the "eq_refl" should be enough --
>>> which means the terms end up containing more and different proofs than
>>> they should. I have not yet tried to reproduce this in the simple
>>> example, since we'd rather avoid "Program" altogether.
>>> Is there some way to make Coq typecheck "test2"; preferably something
>>> that's consistent enough so we could hide it behind the notation that we
>>> use anyway to write these programs?
>>> Kind regards,
>>> Ralf
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] Trouble constructing terms of dependent types involving proofs, Ralf Jung, 03/03/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Jonathan Leivent, 03/03/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Ralf Jung, 03/03/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Clément Pit--Claudel, 03/03/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Robbert Krebbers, 03/03/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Ralf Jung, 03/04/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Gregory Malecha, 03/05/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Ralf Jung, 03/06/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Jonathan Leivent, 03/06/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Gregory Malecha, 03/07/2016
