- From: Clément Pit--Claudel <clement.pit AT gmail.com>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs
- Date: Thu, 3 Mar 2016 14:37:22 -0700
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=clement.pit AT gmail.com; spf=SoftFail smtp.mailfrom=clement.pit AT gmail.com; spf=None smtp.helo=postmaster AT mout.kundenserver.de
- Ironport-phdr: 9a23:B56bhR9h4nFoYf9uRHKM819IXTAuvvDOBiVQ1KB91+0cTK2v8tzYMVDF4r011RmSDdqdtK4P0rGH+4nbGkU+or+5+EgYd5JNUxJXwe43pCcHRPC/NEvgMfTxZDY7FskRHHVs/nW8LFQHUJ2mPw6anHS+4HYoFwnlMkItf6KuStGU0Jj8jrvjs7ToICx2xxOFKYtoKxu3qQiD/uI3uqBFbpgL9x3Sv3FTcP5Xz247bXianhL7+9vitMU7q3cY6Lod8JtLVry/dKAlR5RZCi4nOiY7/p7Frx7GGCCLZ34RVHkhqhtURk3u6BjnUpr1+n/xsud41S+Ge9X3UZg7XD2j6+FgTxq+23RPDCIw7GyC0p84t6lcuh/0/xE=
You can make it look a bit cleaner with a notation, too:
Tactic Notation "!!" uconstr(term) :=
refine term; solve [apply eq_refl].
Definition test2 : expr nil :=
ltac:(!! (Lam _ "x" (Var _ "x" _))).
Clément.
On 03/03/2016 02:26 PM, Clément Pit--Claudel wrote:
> On 03/03/2016 02:23 PM, Ralf Jung wrote:
>> All my experiments with tactics-in-terms lead to the same trouble as
>> plain eq_refl: The tactic is run before the contexts are propagated
>> down, so things don't work. But it may well be that I did this wrong; I
>> have yet to see a successful use of tactics-in-terms ;-)
> Something like this?
> ltac:(refine (Lam _ "x" (Var _ "x" _)); apply eq_refl).
signature.asc
Description: OpenPGP digital signature
- [Coq-Club] Trouble constructing terms of dependent types involving proofs, Ralf Jung, 03/03/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Jonathan Leivent, 03/03/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Ralf Jung, 03/03/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Clément Pit--Claudel, 03/03/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Robbert Krebbers, 03/03/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Ralf Jung, 03/04/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Gregory Malecha, 03/05/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Ralf Jung, 03/06/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Jonathan Leivent, 03/06/2016
- Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs, Gregory Malecha, 03/07/2016
