coq-club - Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs
  • From: Robbert Krebbers <mailinglists AT robbertkrebbers.nl>
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] Trouble constructing terms of dependent types involving proofs
  • Date: Thu, 3 Mar 2016 22:30:05 +0100
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mailinglists AT robbertkrebbers.nl; spf=None smtp.mailfrom=mailinglists AT robbertkrebbers.nl; spf=None smtp.helo=postmaster AT smtp1.science.ru.nl
  • Ironport-phdr: 9a23:mZ46bxQJU21OtsspdwONZpsos9psv+yvbD5Q0YIujvd0So/mwa64YReN2/xhgRfzUJnB7Loc0qyN4/+mBjBLuM3Q+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8KVPFkD3WHsKZpJbzyI7izp/vEMhoVjLqtjgjDomVBvP9ps+GVzOFiIlAz97MrjtLRq8iBXpu5zv5UYCfayLOwESulTCy1jOGQo7uXqswPCRE2B/CgySGITxyBPCQLI9g2yfY38uCH3rPE1jCyTPMn3S78wWC++9I9xTxXihT0bNCQ0+mvakNc2iqYN80HpnAB234OBONLdD/F5ZK6IJd4=
I managed to get this working with type classes, see below. Only now, instead of having an eq_refl for the proof, you have something that type class search generates and which can thus become rather big.
Require Import Decidable List String.
Open Scope string_scope.
Implicit Type (x : string).
Implicit Type (X : list string).
Class IsIn (x : string) (X : list string) := is_in : In x X.
Instance is_in_here x X : IsIn x (x :: X). now left. Qed.
Instance is_in_further x y X : IsIn x X -> IsIn x (y :: X). now right. Qed.
Inductive expr X : Type :=
| Var x `{IsIn x X} : expr X
| App : expr X -> expr X -> expr X
| Lam x : expr (x::X) -> expr X.
Arguments Var {_} _ {_}.
Arguments App {_} _ _.
Arguments Lam {_} _ _.
Definition test2 : expr nil :=
Lam "x" (Lam "y" (App (Var "x") (Var "y"))).
On 03/03/2016 09:26 PM, Ralf Jung wrote:
Hi everybody,
I am trying to use dependent types to represent the free variables of a
deeply embedded language that uses names for binders -- and I am running
into some trouble.
Yeah, I know that "dependent types" and "names for binders" are asking
for trouble. The point is, we actually want to be able to read the
programs we are writing in that deeply embedded language, an deBruijn
indices are rather cryptic. And we need to keep track of whether the
terms are closed, hence the dependent types. This actually worked out
much better than I anticipated, but there still is a serious problem.
The concrete problem we are having is that, if we omit all the type
annotations you want to omit, then Coq fails to type-check the term even
though there is a pretty straight-forward well to add the missing types.
For example:
------ BEGIN ------
Import ListNotations Sumbool.
Obligation Tactic := fail.
Definition in_dec := List.in_dec string_dec.
Definition in_dec_bool x X := proj1_sig (bool_of_sumbool (in_dec x X)).
(* We don't use lists in our actual code, but that doesn't matter.
What matters is that the proof obligation on variables is something
that can be discharged by "eq_refl". *)
| Var x : in_dec_bool x X = true -> expr X
(* This works, but having to state the context in which the
variable is checked is silly. *)
Definition test1 : expr nil :=
Lam _ "x" (Var ["x"] "x" eq_refl).
(* Omitting the context fails. *)
Fail Definition test2 : expr nil :=
Lam _ "x" (Var _ "x" eq_refl).
(* With Program, it works. *)
Program Definition test3 : expr nil :=
--------- END --------------
The comments explain the problem. The "test2" fails with:
The term "eq_refl" has type "in_dec_bool "x" ?l0 = in_dec_bool "x" ?l0" while
it is expected to have type
"in_dec_bool "x" ?l0 = true".
It seems that Coq starts unifying too early or in the wrong order. If it
would just propagate the X downwards, it would notice that the first "_"
can only be "nil", and the second "_" can only be "[x]", and "eq_refl"
actually works.
Using "Program Definition", we can write this down; but this is rather
annoying because Program cannot be used everywhere. Also, in the full
language, we have some trouble with "Program" generating obligations to
prove some equalities, even though the "eq_refl" should be enough --
which means the terms end up containing more and different proofs than
they should. I have not yet tried to reproduce this in the simple
example, since we'd rather avoid "Program" altogether.
Is there some way to make Coq typecheck "test2"; preferably something
that's consistent enough so we could hide it behind the notation that we
use anyway to write these programs?
Kind regards,
Ralf
