- From: nicolas tabareau <nicolas.tabareau AT inria.fr>
- To: coq-club AT inria.fr
- Subject: [Coq-Club] backtracking issue with typeclasses eauto
- Date: Mon, 7 Mar 2016 21:31:42 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tabareau.nicolas AT gmail.com; spf=Pass smtp.mailfrom=tabareau.nicolas AT gmail.com; spf=None smtp.helo=postmaster AT mail-lb0-f174.google.com
- Ironport-phdr: 9a23:+ZVCoRwv8if3E6TXCy+O+j09IxM/srCxBDY+r6Qd0eIXIJqq85mqBkHD//Il1AaPBtWEraIdwLON6OjJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6NyZTunLnpoNX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4jxTbSRqz4S4aU24RlhNTRRTM5hjgU57smir8rOt0nieAbuPsSrVhXzWp6KNiU1f0gS0OLTMw7SmDjM17i6ZSu1S9rhZ22YPdfamUMuB/d+XTZ4VJFiJ6Qs9NWnkZUcuHZIwVAr9ZMA==
Dear All,
It seems that when typeclasses eauto manages
to finish a subgoal with exact, it does not backtrack
on it when the other subgoals fail (below a not too
long example that exhibits the issue).
Do I understand the problem correctly ?
Can it be solved without the seely alias trick
I use ?
Best,
-- Nicolas
Notation "x .1" := (projT1 x) (at level 3).
Parameter myType: Type.
Class Foo (a:myType) := {}.
Class Bar (a:myType) := {}.
Parameter fooTobar : forall a (H : Foo a), {b: myType & Bar b}.
Hint Extern 5 (Bar ?D.1) =>
destruct D; simpl : typeclass_instances.
Hint Extern 1 myType => simple refine (fooTobar _ _).1.
Hint Extern 5 {b: myType & Bar b} =>
simple refine (existT Bar (_:myType) _).
Definition trivial a (H : Foo a) : {b : myType & Bar b}.
Proof.
(* does not try to do simple refine (fooTobar _ _).1. *)
Fail typeclasses eauto with core typeclass_instances.
Abort.
(* just using an alias, to prevent exact to succeed *)
Definition myType2:= myType.
Hint Extern 1 myType2 => simple refine (fooTobar _ _).1.
Hint Extern 5 {b: myType2 & Bar b} =>
simple refine (existT Bar (_:myType2) _).
Definition trivial a (H : Foo a) : {b : myType2 & Bar b}.
Proof.
Defined.
- [Coq-Club] backtracking issue with typeclasses eauto, nicolas tabareau, 03/07/2016
- Re: [Coq-Club] backtracking issue with typeclasses eauto, Jonathan Leivent, 03/07/2016
- Re: [Coq-Club] backtracking issue with typeclasses eauto, nicolas tabareau, 03/07/2016
- Re: [Coq-Club] backtracking issue with typeclasses eauto, Matthieu Sozeau, 03/07/2016
