- From: nicolas tabareau <nicolas.tabareau AT inria.fr>
- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] backtracking issue with typeclasses eauto
- Date: Mon, 7 Mar 2016 22:11:09 +0100
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=tabareau.nicolas AT gmail.com; spf=Pass smtp.mailfrom=tabareau.nicolas AT gmail.com; spf=None smtp.helo=postmaster AT mail-lb0-f182.google.com
- Ironport-phdr: 9a23:2D/knR1pI3/+8Dy0smDT+DRfVm0co7zxezQtwd8ZsegeK/ad9pjvdHbS+e9qxAeQG96LtLQU0qGP6PGocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0ILnjqvroMybSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBK79ZuEzSaFSJDUgKWE8osPx5iPOVQ+e2nxJVGQdlR5BGE7Z5RvzRJr4rwP7sPB80W+UJ57YV7cxDDKj5KBvQQSglC4NPiQ0+Xyf3spxh6VfqQnnuxV1ypTZaZy9Nfxkf6qbc8lMFjkJZdpYSyEUWtD0VIAIFedUZes=
Thanks for the trick but that is indeed not what I was looking for.
Have you a typical example of auto-like tactics on your github ?
On Mon, Mar 7, 2016 at 10:00 PM, Jonathan Leivent <jonikelee AT gmail.com> wrote:
You have to inline the mytype hint into the sigT hint, like so:
Hint Extern 5 {b: myType & Bar b} =>
simple refine (existT Bar (_:myType) _); [simple refine (fooTobar _ _).1 |].
Yes, it's ugly. I think the problem is that typeclasses eauto, as well as auto and eauto, all to varying degrees don't fully backtrack - even in 8.5. Interestingly, the best of the bunch is auto.
Hopefully, someone will make the auto tactics all fully backtrack at some point. In the mean time, I have given up on the auto tactics - and instead write my own backtracking routines using 8.5's "+" operator, the new multimatch tactical, and some other tricks.
-- Jonathan
On 03/07/2016 03:31 PM, nicolas tabareau wrote:
Dear All,
It seems that when typeclasses eauto manages
to finish a subgoal with exact, it does not backtrack
on it when the other subgoals fail (below a not too
long example that exhibits the issue).
Do I understand the problem correctly ?
Can it be solved without the seely alias trick
I use ?
Best,
-- Nicolas
Notation "x .1" := (projT1 x) (at level 3).
Parameter myType: Type.
Class Foo (a:myType) := {}.
Class Bar (a:myType) := {}.
Parameter fooTobar : forall a (H : Foo a), {b: myType & Bar b}.
Hint Extern 5 (Bar ?D.1) =>
destruct D; simpl : typeclass_instances.
Hint Extern 1 myType => simple refine (fooTobar _ _).1.
simple refine (existT Bar (_:myType) _).
Definition trivial a (H : Foo a) : {b : myType & Bar b}.
Proof.
(* does not try to do simple refine (fooTobar _ _).1. *)
Fail typeclasses eauto with core typeclass_instances.
Abort.
(* just using an alias, to prevent exact to succeed *)
Definition myType2:= myType.
Hint Extern 1 myType2 => simple refine (fooTobar _ _).1.
Hint Extern 5 {b: myType2 & Bar b} =>
simple refine (existT Bar (_:myType2) _).
Definition trivial a (H : Foo a) : {b : myType2 & Bar b}.
Proof.
Defined.
Nicolas Tabareau
Researcher at Inria
Ascola Group, Nantes
Researcher at Inria
- [Coq-Club] backtracking issue with typeclasses eauto, nicolas tabareau, 03/07/2016
- Re: [Coq-Club] backtracking issue with typeclasses eauto, Jonathan Leivent, 03/07/2016
- Re: [Coq-Club] backtracking issue with typeclasses eauto, nicolas tabareau, 03/07/2016
- Re: [Coq-Club] backtracking issue with typeclasses eauto, Matthieu Sozeau, 03/07/2016
