coq-club - Re: [Coq-Club] backtracking issue with typeclasses eauto
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] backtracking issue with typeclasses eauto
  • Date: Mon, 07 Mar 2016 21:37:33 +0000
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=mattam AT mattam.org; spf=Pass smtp.mailfrom=matthieu.sozeau AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f48.google.com
  • Ironport-phdr: 9a23:Z9o97x3hDC4vmWe+smDT+DRfVm0co7zxezQtwd8ZsegVIvad9pjvdHbS+e9qxAeQG96LtLQU0qGP7/CocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC0ILnjqvrp82bSj4LrQT+SIs6FA+xowTVu5teqqpZAYF19CH0pGBVcf9d32JiKAHbtR/94sCt4MwrqHwI6Lpyv/JHBK79ZuEzSaFSJDUgKWE8osPx5jfZSg7aw3IATmUXnwcAOA/X4RjnFsP0uzfmv+9V3SCGIcTzC7cuVmLxvO9QVBb0hXJfZHYC+2bNh5kogQ==
Hi,
   Set Typeclasses Dependency Order. is what you need here,
it will correctly backtrack on exact a, and actually try to solve the
?g1 : myType goal before the ?g2 : Bar ?g1 goal. The reason it is
an option is that many libraries rely on the old behavior, which can
be a huge performance gain depending on the situation.
  Beware that your Hint Extern's actually do some resolution before
producing goals on which typeclasses eauto can backtrack, e.g. in
the successful trace:
Debug: 1: eapply existT on {b : myType & Bar b}
Debug: 1.1.1: exact a on myType
Debug: 1.2: no match for (Bar a) , 1 possibilities
Debug: Backtracking after exact a
Debug: 1.1: exact H on (Foo ?m)
Debug: 1.1.2: (*external*) simple refine (fooTobar _ _) .1 on myType
Debug: 1.2.1: (*external*) destruct D; simpl on (Bar (fooTobar a H) .1)
Debug: 1.2.1.1.1: exact b on (Bar x)
The Debug: 1.1 line is an internal call to resolution due to the 1.1.2
extern call, the rest will not backtrack on this choice. Moving
typeclasses eauto (along with auto ...) to the new engine is part of
my current plans. This should bring Hint Externs with multiple
successes as well.
Best,
-- Matthieu
On Mon, Mar 7, 2016 at 10:12 PM nicolas tabareau <nicolas.tabareau AT inria.fr> wrote:
Thanks for the trick but that is indeed not what I was looking for.
Have you a typical example of auto-like tactics on your github ?
On Mon, Mar 7, 2016 at 10:00 PM, Jonathan Leivent <jonikelee AT gmail.com> wrote:
You have to inline the mytype hint into the sigT hint, like so:
Hint Extern 5 {b: myType & Bar b} =>
  simple refine (existT Bar (_:myType) _); [simple refine (fooTobar _ _).1 |].
Yes, it's ugly.  I think the problem is that typeclasses eauto, as well as auto and eauto, all to varying degrees don't fully backtrack - even in 8.5.  Interestingly, the best of the bunch is auto.
Hopefully, someone will make the auto tactics all fully backtrack at some point.  In the mean time, I have given up on the auto tactics - and instead write my own backtracking routines using 8.5's "+" operator, the new multimatch tactical, and some other tricks.
-- Jonathan
On 03/07/2016 03:31 PM, nicolas tabareau wrote:
Dear All,
It seems that when typeclasses eauto manages
to finish a subgoal with exact, it does not backtrack
on it when the other subgoals fail (below a not too
long example that exhibits the issue).
Do I understand the problem correctly ?
Can it be solved without the seely alias trick
I use ?
Best,
-- Nicolas
Notation "x .1" := (projT1 x) (at level 3).
Parameter myType: Type.
Class Foo (a:myType) := {}.
Class Bar (a:myType) := {}.
Parameter fooTobar : forall a (H : Foo a), {b: myType & Bar b}.
Hint Extern 5 (Bar ?D.1) =>
     destruct D; simpl : typeclass_instances.
Hint Extern 1 myType => simple refine (fooTobar _ _).1.
   simple refine (existT Bar (_:myType) _).
Definition trivial a (H : Foo a) : {b : myType & Bar b}.
Proof.
   (* does not try to do simple refine (fooTobar _ _).1. *)
   Fail typeclasses eauto with core typeclass_instances.
Abort.
(* just using an alias, to prevent exact to succeed *)
Definition myType2:= myType.
Hint Extern 1 myType2 => simple refine (fooTobar _ _).1.
Hint Extern 5 {b: myType2 & Bar b} =>
   simple refine (existT Bar (_:myType2) _).
Definition trivial a (H : Foo a) : {b : myType2 & Bar b}.
Proof.
Defined.
Nicolas Tabareau
Researcher at Inria
Ascola Group, Nantes
