coq-club - Re: [Coq-Club] backtracking issue with typeclasses eauto
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] backtracking issue with typeclasses eauto
  • Date: Mon, 7 Mar 2016 16:28:33 -0500
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f44.google.com
  • Ironport-phdr: 9a23:ERoK9hHrUTqUsniguWmR+Z1GYnF86YWxBRYc798ds5kLTJ75osmwAkXT6L1XgUPTWs2DsrQf27WQ4/mrADdRqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7/0q8SYOl4ZzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IZ4yhIP99FeAQTGl+cjN92Mq+vh7aCACL+3E0U2MMkxMODRKWwgv9W8LTtS3zqup03mG+MMzoQLYoEWCg6KFqSxLshSovODsw8WWRgct12vEI6Cm9rgByltaHKLqeM+BzK/6FcA==
On 03/07/2016 04:11 PM, nicolas tabareau wrote:
Thanks for the trick but that is indeed not what I was looking for.
Have you a typical example of auto-like tactics on your github ?
Unfortunately, none that involve typeclasses, and none that have the "auto-like" ability to make use of hint dbs.
One could write an auto-like tactic that uses hint dbs and fully backtracks by using "+" and multimatch, in combination with Gregory Malecha's coq-ltac-iter plugin (https://github.com/gmalecha/coq-ltac-iter) to iterate over a hint db. Unfortunately, I don't think his plugin handles Extern hints yet.
-- Jonathan
On Mon, Mar 7, 2016 at 10:00 PM, Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
You have to inline the mytype hint into the sigT hint, like so:
Hint Extern 5 {b: myType & Bar b} =>
simple refine (existT Bar (_:myType) _); [simple refine (fooTobar _ _).1
Yes, it's ugly. I think the problem is that typeclasses eauto, as well as
auto and eauto, all to varying degrees don't fully backtrack - even in
8.5. Interestingly, the best of the bunch is auto.
Hopefully, someone will make the auto tactics all fully backtrack at some
point. In the mean time, I have given up on the auto tactics - and instead
write my own backtracking routines using 8.5's "+" operator, the new
multimatch tactical, and some other tricks.
-- Jonathan
On 03/07/2016 03:31 PM, nicolas tabareau wrote:
Dear All,
It seems that when typeclasses eauto manages
to finish a subgoal with exact, it does not backtrack
on it when the other subgoals fail (below a not too
long example that exhibits the issue).
Do I understand the problem correctly ?
Can it be solved without the seely alias trick
I use ?
Best,
-- Nicolas
Notation "x .1" := (projT1 x) (at level 3).
Parameter myType: Type.
Class Foo (a:myType) := {}.
Class Bar (a:myType) := {}.
Parameter fooTobar : forall a (H : Foo a), {b: myType & Bar b}.
Hint Extern 5 (Bar ?D.1) =>
destruct D; simpl : typeclass_instances.
Hint Extern 1 myType => simple refine (fooTobar _ _).1.
simple refine (existT Bar (_:myType) _).
Definition trivial a (H : Foo a) : {b : myType & Bar b}.
Proof.
(* does not try to do simple refine (fooTobar _ _).1. *)
Fail typeclasses eauto with core typeclass_instances.
Abort.
(* just using an alias, to prevent exact to succeed *)
Definition myType2:= myType.
Hint Extern 1 myType2 => simple refine (fooTobar _ _).1.
Hint Extern 5 {b: myType2 & Bar b} =>
simple refine (existT Bar (_:myType2) _).
Definition trivial a (H : Foo a) : {b : myType2 & Bar b}.
Proof.
Defined.
