- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] typeclasses and rewriting
- Date: Thu, 28 Apr 2016 13:18:36 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f170.google.com
- Ironport-phdr: 9a23:fosCHRE1W2nfaTOQLVxKfJ1GYnF86YWxBRYc798ds5kLTJ75osmwAkXT6L1XgUPTWs2DsrQf27qQ4/yrADRfqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7D0q8GYOl0XzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IZ4yhIP99FeAQTGl+cjN92Mq+vh7aCACL+3E0U2MMkxMODRKWwgv9W8LTtS3zqup03mG+MMzoQLYoEWCg6KFqSxLshSovODsw8WWRgct12vEI6Cm9rgByltaHKLqeM+BzK/6FcA==
On 04/28/2016 01:02 PM, William Mansky wrote:
Hello,
I've been trying to use typeclasses to carry around contexts of definitions and assumptions. Mostly, this works as I would like (i.e., as with locales in Isabelle), but I've run into some problems when proving an equation in one section and trying to rewrite with it in another. Here's a minimal example:
Require Import Setoid.
Class test := {A : Type; a : A; b : A; Heq : a = b}.
Section test.
Context {T : test}.
Lemma test_iff : forall c, a = c <-> b = c.
Proof.
rewrite Heq; split; intro; auto.
Qed.
End test.
Section test2.
Context {T : test}.
Lemma test2 : forall d, a = d -> b = d.
Proof.
intros.
try rewrite test_iff in *. (* This doesn't work. *)
rewrite test_iff in H. (* This does. *)
auto.
Qed.
End test2.
This problem doesn't show up if both lemmas are in a single section, but I want to be able to use the same context across multiple files, so that doesn't really help. Does anyone have any suggestions?
Thanks,
William
I've seen varieties of this bug before - I thought it was reported, but don't recall the number or subject. A quick bugzilla search didn't turn up any obvious match either...
One workaround is to declare your rewrite rule as a hint in a rewrite db:
Hint Rewrite @test_iff : my_rwdb.
Then, "autorewrite with my_rwdb in *" works.
Another is to roll your own "in *" tactical for rewrites that iterates over the hypotheses and does "in H" for each:
repeat match goal with H :_ |- _ => rewrite test_iff in H end.
If you only want to rewrite once per hyp, then you'll need a different way to do the iteration - probably reverting each hyp after it is tried. Or a hyp iterator (I have one, but it is a hacked-up mess. Gregory Malecha has a much nicer plugin: https://github.com/gmalecha/coq-ltac-iter).
-- Jonathan
- [Coq-Club] typeclasses and rewriting, William Mansky, 04/28/2016
- Re: [Coq-Club] typeclasses and rewriting, Jonathan Leivent, 04/28/2016
- Re: [Coq-Club] typeclasses and rewriting, Abhishek Anand, 04/28/2016
- Re: [Coq-Club] typeclasses and rewriting, Matthieu Sozeau, 04/28/2016
