- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] typeclasses and rewriting
- Date: Thu, 28 Apr 2016 20:51:40 +0000
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=mattam AT mattam.org; spf=Pass smtp.mailfrom=matthieu.sozeau AT gmail.com; spf=None smtp.helo=postmaster AT mail-wm0-f52.google.com
- Ironport-phdr: 9a23:mf2GtRM9p+Gqc5gufr4l6mtUPXoX/o7sNwtQ0KIMzox0KP/zrarrMEGX3/hxlliBBdydsKIUzbqK+Pm9AyQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTnkbDusMSOOU1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKMhCLdcET4OMmYv5cStuwOQYxGI4y45W3kKkhtFHkD+6wP3V4q55i7zqvZ03QGfNNHqRLVyXi6tufQ4ACT0gTsKYmZquFrcjdZ92fpW
Hi,
Indeed, that might be surprising, rewrite c in * |- prevents rewriting in any hypothesis
which is referenced in c. If c contains an existential variable like
@test_iff ?X{...__:=H} here, then the rewrite is not attempted in H at all.
So the "problem" would rather be that we did not instantiate ?X early enough here
to see that test_iff doesn't depend on H...
This behavior was implemented to solve bug
This is done so that if you do rewrite (lemma H) in * it won't rewrite in H and follow by
rewriting with (lemma H) in the next hypotheses with the _new_ H. Actually
this is not specified exactly in the documentation, only the rewrite H case is
(without a lemma). Maybe we should relax this to allow H to appear in existentials
in the lemma, i.e. not rigidly?
-- Matthieu
On Thu, Apr 28, 2016 at 8:04 PM Jonathan Leivent <jonikelee AT gmail.com> wrote:
On 04/28/2016 01:20 PM, Abhishek Anand wrote:
> Similar to what Jonathan is suggesting,
> while rewriting with lemmas that have implicit arguments, or adding hints
> to a rewrite DB, I prepend "@" to prevent Coq from (I think) prematurely
> specializing the lemmas by instantiating the implicits. This helps in your
> case too, perhaps for a different reason.
> try rewrite @test_iff in *. (* succeeds *)
It's interesting that this variant succeeds, since "rewrite test_iff in
H" doesn't need the "@", and the error message "Error: Found no subterm
matching "a = ?a" in the current goal." appears to suggests that the
implicit arg was properly matched (since it didn't complain about it).
-- Jonathan
> -- Abhishek
> http://www.cs.cornell.edu/~aa755/
> On Thu, Apr 28, 2016 at 1:02 PM, William Mansky <wmansky AT seas.upenn.edu>
> wrote:
>> Hello,
>> I've been trying to use typeclasses to carry around contexts of
>> definitions and assumptions. Mostly, this works as I would like (i.e., as
>> with locales in Isabelle), but I've run into some problems when proving an
>> equation in one section and trying to rewrite with it in another. Here's a
>> minimal example:
>> Require Import Setoid.
>> Class test := {A : Type; a : A; b : A; Heq : a = b}.
>> Section test.
>> Context {T : test}.
>> Lemma test_iff : forall c, a = c <-> b = c.
>> Proof.
>> rewrite Heq; split; intro; auto.
>> Qed.
>> End test.
>> Section test2.
>> Context {T : test}.
>> Lemma test2 : forall d, a = d -> b = d.
>> Proof.
>> intros.
>> try rewrite test_iff in *. (* This doesn't work. *)
>> rewrite test_iff in H. (* This does. *)
>> auto.
>> Qed.
>> End test2.
>> This problem doesn't show up if both lemmas are in a single section, but I
>> want to be able to use the same context across multiple files, so that
>> doesn't really help. Does anyone have any suggestions?
>> Thanks,
>> William
- [Coq-Club] typeclasses and rewriting, William Mansky, 04/28/2016
- Re: [Coq-Club] typeclasses and rewriting, Jonathan Leivent, 04/28/2016
- Re: [Coq-Club] typeclasses and rewriting, Abhishek Anand, 04/28/2016
- Re: [Coq-Club] typeclasses and rewriting, Matthieu Sozeau, 04/28/2016
