- From: Abhishek Anand <abhishek.anand.iitg AT gmail.com>
- To: coq-club <coq-club AT inria.fr>
- Subject: Re: [Coq-Club] typeclasses and rewriting
- Date: Thu, 28 Apr 2016 13:20:39 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=abhishek.anand.iitg AT gmail.com; spf=Pass smtp.mailfrom=abhishek.anand.iitg AT gmail.com; spf=None smtp.helo=postmaster AT mail-yw0-f174.google.com
- Ironport-phdr: 9a23:Rhoz1RzJ5u1HufPXCy+O+j09IxM/srCxBDY+r6Qd0ewWIJqq85mqBkHD//Il1AaPBtWLraIYwLOO7OjJYi8p39WoiDg6aptCVhsI2409vjcLJ4q7M3D9N+PgdCcgHc5PBxdP9nC/NlVJSo6lPwWB6kO74TNaIBjjLw09fr2zQd6CyZTrnLnqpNX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULYQWD8hKiU+4NDhnRjFVwqGoHUGBDY4iB1NViHP7BDhXpry+gL8v+xxkH2TN833VrA5WnKr6a5tRFnpiTsIHzE8+WDTzMd3ifQI81qauxVjztuMM8muP/1kc/aFcA==
Similar to what Jonathan is suggesting,
while rewriting with lemmas that have implicit arguments, or adding hints to a rewrite DB, I prepend "@" to prevent Coq from (I think) prematurely specializing the lemmas by instantiating the implicits. This helps in your case too, perhaps for a different reason.
-- Abhishek
http://www.cs.cornell.edu/~aa755/On Thu, Apr 28, 2016 at 1:02 PM, William Mansky <wmansky AT seas.upenn.edu> wrote:
Hello,
I've been trying to use typeclasses to carry around contexts of definitions and assumptions. Mostly, this works as I would like (i.e., as with locales in Isabelle), but I've run into some problems when proving an equation in one section and trying to rewrite with it in another. Here's a minimal example:
Require Import Setoid.
Class test := {A : Type; a : A; b : A; Heq : a = b}.
Section test.
Context {T : test}.
Lemma test_iff : forall c, a = c <-> b = c.
Proof.
rewrite Heq; split; intro; auto.
Qed.
End test.
Section test2.
Context {T : test}.
Lemma test2 : forall d, a = d -> b = d.
Proof.
intros.
try rewrite test_iff in *. (* This doesn't work. *)
rewrite test_iff in H. (* This does. *)
auto.
Qed.
End test2.
This problem doesn't show up if both lemmas are in a single section, but I want to be able to use the same context across multiple files, so that doesn't really help. Does anyone have any suggestions?
Thanks,
William
- [Coq-Club] typeclasses and rewriting, William Mansky, 04/28/2016
- Re: [Coq-Club] typeclasses and rewriting, Jonathan Leivent, 04/28/2016
- Re: [Coq-Club] typeclasses and rewriting, Abhishek Anand, 04/28/2016
- Re: [Coq-Club] typeclasses and rewriting, Matthieu Sozeau, 04/28/2016
