- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] typeclasses and rewriting
- Date: Thu, 28 Apr 2016 14:03:47 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f174.google.com
- Ironport-phdr: 9a23:v8OM9RFQ5u4RNOjmSFCfU51GYnF86YWxBRYc798ds5kLTJ75osmwAkXT6L1XgUPTWs2DsrQf27qQ4/yrADVRqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7D0q8GYOlwZzBOGIppMbzyO5T3LsccXhYYwYo0Q8TDu5kVyRuJN2GlzLkiSlRuvru25/Zpk7jgC86l5r50IZ4yhIP99FeAQTGl+cjN92Mq+vh7aCACL+3E0U2MMkxMODRKWwgv9W8LTtS3zqup03mG+MMzoQLYoEWCg6KFqSxLshSovODsw8WWRgct12vEI6Cm9rgByltaHKLqeM+BzK/6FcA==
On 04/28/2016 01:20 PM, Abhishek Anand wrote:
Similar to what Jonathan is suggesting,
while rewriting with lemmas that have implicit arguments, or adding hints
to a rewrite DB, I prepend "@" to prevent Coq from (I think) prematurely
specializing the lemmas by instantiating the implicits. This helps in your
case too, perhaps for a different reason.
try rewrite @test_iff in *. (* succeeds *)
It's interesting that this variant succeeds, since "rewrite test_iff in H" doesn't need the "@", and the error message "Error: Found no subterm matching "a = ?a" in the current goal." appears to suggests that the implicit arg was properly matched (since it didn't complain about it).
-- Jonathan
-- Abhishek
http://www.cs.cornell.edu/~aa755/
On Thu, Apr 28, 2016 at 1:02 PM, William Mansky
<wmansky AT seas.upenn.edu>
wrote:
Hello,
I've been trying to use typeclasses to carry around contexts of
definitions and assumptions. Mostly, this works as I would like (i.e., as
with locales in Isabelle), but I've run into some problems when proving an
equation in one section and trying to rewrite with it in another. Here's a
minimal example:
Require Import Setoid.
Class test := {A : Type; a : A; b : A; Heq : a = b}.
Section test.
Context {T : test}.
Lemma test_iff : forall c, a = c <-> b = c.
Proof.
rewrite Heq; split; intro; auto.
Qed.
End test.
Section test2.
Context {T : test}.
Lemma test2 : forall d, a = d -> b = d.
Proof.
intros.
try rewrite test_iff in *. (* This doesn't work. *)
rewrite test_iff in H. (* This does. *)
auto.
Qed.
End test2.
This problem doesn't show up if both lemmas are in a single section, but I
want to be able to use the same context across multiple files, so that
doesn't really help. Does anyone have any suggestions?
Thanks,
William
- [Coq-Club] typeclasses and rewriting, William Mansky, 04/28/2016
- Re: [Coq-Club] typeclasses and rewriting, Jonathan Leivent, 04/28/2016
- Re: [Coq-Club] typeclasses and rewriting, Abhishek Anand, 04/28/2016
- Re: [Coq-Club] typeclasses and rewriting, Matthieu Sozeau, 04/28/2016
