- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] question about universes and equalities
- Date: Sun, 8 May 2016 15:23:35 -0400
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f173.google.com
- Ironport-phdr: 9a23:XAwhYxeHzsx3+/Q2I8WbXnj2lGMj4u6mDksu8pMizoh2WeGdxc6+ZR7h7PlgxGXEQZ/co6odzbGG4ua5ASdZu87JmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviqtuKO04R3mL1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdfFXEtN30/zMztrxjKCwWVtVUGVWBDsB1OChTF5ReyeprwrCb8qqIp2i6cPM77Sb05cTun5qZvDhTvjXFUZHYC7GjLh5ko3+pgqxW7qkknzg==
On 05/08/2016 02:30 PM, Jason Gross wrote:
It's not provable unless you assume, e.g., univalence. (The other
direction, @eq Set S1 S2 -> @eq Type S1 S2, however, is provable in vanilla
Coq.) Since Coq is consistent with univalence, it's not possible to have
two Sets that are @eq Type but provably not @eq Set. (If you just want two
that are @eq Type and not provable @eq Set, S1 and S2 in the context of
your goal after [intros] will do.) I don't know if there are any models
which would validate this, but the HoTT mailing list might be a reasonable
place to ask. (Under the homotopy interpretation, the idea would be that
somehow all of the paths between S1 and S2 "go through" types which do not
live in Set.)
-Jason
Thanks for the quick reply, Jason.
My primary concern is if using certain "more generic" lemmas and tactics that do things in Type instead of Set is a problem - which it appears to be (for example, using eq_rect to get a more generic definition, when eq_rec would suffice for some usages).
I could start using Polymorphic definitions - but it will still be the case sometimes that I will have a relationship R T1 T2 where T1 and T2 are initially at some higher universe level (such as Type), but reduce to a lower one (such as Set) at some point. Which could then break the intention of R, even if R is polymorphic.
Does Coq have a way to declare universe minimization as a type of reduction on terms? Meaning that if I have R T1 T2 where T1 and T2 are both Types, but reduction/substitution changes this to R S1 S2 where S1 and S2 are both Sets, can some kind of reduction also modify R's implicit universe arguments?
For example:
Polymorphic Definition peq@{i} {T:Type@{i}}(S1 S2:T) := eq S1 S2.
Variables S1 S2 : Set.
Definition T1 : Type := S1.
Definition T2 : Type := S2.
Goal peq T1 T2 -> @eq Set S1 S2.
cbv.
Even though peq is polymorphic, once the peq term is constructed on T1 T2, the universe level is fixed, and there is no way to prove this goal.
-- Jonathan
On Sun, May 8, 2016 at 2:10 PM, Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
I'm hitting some problems that I think are related to equalities in
different universes. For example, consider:
Goal forall S1 S2:Set, @eq Type S1 S2 -> @eq Set S1 S2.
Is this provable in Coq? If not, then does that mean it is possible to
have two Sets in Coq such that they are (@eq Type) but not (@eq Set)? What
would that possibly mean?
-- Jonathan
- [Coq-Club] question about universes and equalities, Jonathan Leivent, 05/08/2016
- Re: [Coq-Club] question about universes and equalities, Jason Gross, 05/08/2016
- Re: [Coq-Club] question about universes and equalities, Jonathan Leivent, 05/08/2016
- Re: [Coq-Club] question about universes and equalities, Jonathan Leivent, 05/09/2016
- Re: [Coq-Club] question about universes and equalities, Matthieu Sozeau, 05/09/2016
- Re: [Coq-Club] question about universes and equalities, Jason Gross, 05/09/2016
- Re: [Coq-Club] question about universes and equalities, Stefan Monnier, 05/09/2016
