coq-club - Re: [Coq-Club] question about universes and equalities
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] question about universes and equalities
  • Date: Sun, 8 May 2016 19:08:29 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f172.google.com
  • Ironport-phdr: 9a23:mKhu6hblZ3Afv/GoiXF83+7/LSx+4OfEezUN459isYplN5qZpci7bnLW6fgltlLVR4KTs6sC0LqH9fm4EjVdvt6oizMrTt9lb1c9k8IYnggtUoauKHbQC7rUVRE8B9lIT1R//nu2YgB/Ecf6YEDO8DXptWZBUiv2OQc9HOnpAIma153xjLDjvcSLKFwV23KUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtRrtBST8iLmod5cvxtBCFQxHcyGEbVzA0lRxBHwjM6lneU5bvvy3m/r5/3y+bPsDyQL0cVjGr7qMtQxjt3nRUfwUl+X3a35QjxJlQpwis8kRy
On 05/08/2016 05:23 PM, Jason Gross wrote:
What error message do you get if you do [into H; pose (H : @peq@{Set}
Type@{Set}
T1 T2).]? In particular, which universe variable is it refusing to
minimize, and why? (My approach to [Set] with universe polymorphism is
mostly "don't use it". Note that [@eq Type@{i} A B -> @eq Type@{j} A B]
does not hold for [i > j], but you don't run into these other problems,
which are generally a result of Coq refusing to minimize some universes to
Set (allowing minimization in these cases has resulted in even more issues,
sometimes in cases where [Set] was not explicitly mentioned, so Mathieu
chose to forbid some minimizations).)
Note that I'm not using universes in the sense of having (prior to trying to fix this problem) any definitions that use explicit universes or polymorphism. I just have some definitions that implicitly declare args as Types (like A in definition foo{A}(a : A)...), and uses of those definitions on Sets.
I'd rather not use universe polymorphism. However, I thought I was being dragged in its direction. But, I'm not sure what's going on. Here's an example:
Variables S1 S2 : Set.
Goal @eq Type S1 S2 -> @eq Type S1 S2.
intro H.
Fail tauto.
assumption.
Qed.
Why does tauto fail, when assumption succeeds? Is this a bug in tauto? Or, is there an explanation having to do with universe levels that absolves tauto of missing this easily proven case, but is consistent with assumption succeeding?
Another example:
Definition T1 : Type := S1.
Definition T2 : Type := S2.
Goal T1 = T1.
congruence.
Undo.
tauto.
Undo.
unfold T1.
Fail congruence.
tauto.
Qed.
Here, tauto is well behaved, but congruence is not. Since I am seeing these strange behaviors through the lens of various unanticipated tactic failures, I'm not sure whether I'm seeing some expected behavior on the part of universes that I have to compensate for (how?), or if I'm hitting tactic bugs.
-- Jonathan
