coq-club - Re: [Coq-Club] question about universes and equalities
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] question about universes and equalities
  • Date: Mon, 9 May 2016 12:15:34 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f174.google.com
  • Ironport-phdr: 9a23:Pw+QiRUI+yh/6SsxBcJSNR+3f1bV8LGtZVwlr6E/grcLSJyIuqrYZheOt8tkgFKBZ4jH8fUM07OQ6PCxHzVaqsbe+Fk5M7VyFDY9wf0MmAIhBMPXQWbaF9XNKxIAIcJZSVV+9Gu6O0UGUOz3ZlnVv2HgpWVKQka3CwN5K6zPF5LIiIzvjqbpq8yVOl8D1GX1SIgxBSv1hD2ZjtMRj4pmJ/R54TryiVwMRd5rw3h1L0mYhRf265T41pdi9yNNp6BprJYYAu2pN5g/GLdfFXEtN30/zMztrxjKCwWVtVUGVWBDsB1OChTF5ReyeprwrCb8qqIp2i6cPM77Sb05cTun5qZvDhTvjXFUZHYC7GjLh5ko3+pgqxW7qkknzg==
On 05/09/2016 12:09 PM, Jason Gross wrote:
The rewrite tactic fails with this error message when it finds a subterm
and instantiates the lemma, but refining with the lemma does not change the
goal; I suspect it plays a role in determining which places to rewrite in.
Sorry - I should have realized that it was rewrite doing the complaining. I guess I'm getting edgy about this universe thing.
-- Jonathan
On Mon, May 9, 2016, 12:00 PM Jonathan Leivent
<jonikelee AT gmail.com>
wrote:
I attempted to write a tactic that would lower the universe level of an
equality conclusion, so as to avoid these problems - but it has a
problem of its own:
Variable S1 S2 : Set.
Ltac lowereq :=
lazymatch goal with
(*replace any equality by a min-universe-leveled one*)
|- @eq _ ?X ?Y => assert (X = Y) as H; [|rewrite H; reflexivity]
end.
Goal @eq Type S1 S1.
Fail lowereq. (*Error: Tactic generated a subgoal identical to the
original goal*)
Admitted.
Goal @eq Type S1 S2.
lowereq. (*works properly*)
lowereq. (*no complaints about identical subgoals here*)
Admitted.
Why does Coq complain about a subgoal being identical to the original in
the first Goal case? It doesn't do that elsewhere (as the second Goal
shows). What is it trying to prevent? Isn't that a job for the
progress tactical?
-- Jonathan
