coq-club - Re: [Coq-Club] question about universes and equalities
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] question about universes and equalities
  • Date: Mon, 9 May 2016 11:59:33 -0400
  • Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f54.google.com
  • Ironport-phdr: 9a23:JGqQThSlBTig6PAlsExa65KRodpsv+yvbD5Q0YIujvd0So/mwa64Zx2N2/xhgRfzUJnB7Loc0qyN4/GmADZLscnJmUtBWaIPfidNsd8RkQ0kDZzNImzAB9muURYHGt9fXkRu5XCxPBsdMs//Y1rPvi/6tmZKSV3BPAZ4bt74BpTVx5zukbviqtuKOU4Y23KUWvBbElaflU3prM4YgI9veO4a6yDihT92QdlQ3n5iPlmJnhzxtY+a9Z9n9DlM6bp6r5YTGfayQ6NtRrtBST8iLmod5cvxtBCFQxHcyGEbVzA0lRxBHwjM6lneU5bvvy3m/r5/3y+bPsDyQL0cVjGr7qMtQxjt3nRUfwUl+X3a35QjxJlQpwis8kRy
I attempted to write a tactic that would lower the universe level of an equality conclusion, so as to avoid these problems - but it has a problem of its own:
Variable S1 S2 : Set.
Ltac lowereq :=
lazymatch goal with
(*replace any equality by a min-universe-leveled one*)
|- @eq _ ?X ?Y => assert (X = Y) as H; [|rewrite H; reflexivity]
end.
Goal @eq Type S1 S1.
Fail lowereq. (*Error: Tactic generated a subgoal identical to the original goal*)
Admitted.
Goal @eq Type S1 S2.
lowereq. (*works properly*)
lowereq. (*no complaints about identical subgoals here*)
Admitted.
Why does Coq complain about a subgoal being identical to the original in the first Goal case? It doesn't do that elsewhere (as the second Goal shows). What is it trying to prevent? Isn't that a job for the progress tactical?
-- Jonathan
