- To: Coq Club <coq-club AT inria.fr>
- Subject: [Coq-Club] LEM variants vs. proof relevance
- Date: Sat, 28 May 2016 11:47:59 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qg0-f53.google.com
- Ironport-phdr: 9a23:WZyxpRYPkrNKpLoSCnNV2Hn/LSx+4OfEezUN459isYplN5qZpcu4bnLW6fgltlLVR4KTs6sC0LqH9f24Ej1Yqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7H0psWYMl0ArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIZoGJ/3dKUgTLFeEC9ucyVsvJWq5lH/Sl6k4WJUeWELmFIcCA/cqRr+Q53Zsy3gt+M71jPMbuPsSrVhezOk5rtrQRmgrCoGKTM/7CmDiMt2jaFWpB+sjxN6yo/QJoqSMawtLevmYdoGSD8ZDY5qXCtbD9b5NtNXAg==
Coq.Logic.ClassicalFacts shows that excluded middle (LEM) implies
proof irrelevance. I'm working with a form of proof relevance,
but would still like some alternative to LEM - which would allow
me to have "forall P, P \/ something else about P" that would
still form an excluded middle in that both sides of the "\/" could
not be true at the same time. Because, it looks like if I can
have such a thing, then I can get the benefits of proof
irrelevance without full proof irrelevance: It would allow me to
easily find for any arbitrary Prop P, a P' such that P <->
P' and P' is irrelevant (forall p q : P', p = q). As pointed out
in the "Proof irrelevant Specif?" thread, coincidentally, this is
already possible in Coq without any axioms for all P that are
type-decidable ({P}+{~P}) - because that allows a version of P
that is a boolean predicate. The form of proof relevance I'm
working with makes it the case for any P that is prop-decidable (P
\/ ~P : locally LEM). This last bit I'm looking for would make it
the case for all P period. The first thing I though of was "forall P, P \/ (P \/ ~P ->
~P)". Interestingly, this is not a tautology in Coq (at least
tauto doesn't think so), but it seems like it's just stating the
obvious. Could it be possible that "forall P, P \/ (P \/ ~P ->
~P)" does not imply proof irrelevance? If so, then it's just what
I need. Otherwise, there is an infinite regress of these:
If not "nlem 1 P", what about "nlem n P" for some high enough n? As it turns out, I really only need to claim the existence of some arbitrary "something else about P":
Might that be safe enough (not imply proof irrelevance)? -- Jonathan
- [Coq-Club] LEM variants vs. proof relevance, Jonathan Leivent, 05/28/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Gérard Huet, 05/28/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jonathan Leivent, 05/28/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Arnaud Spiwack, 05/28/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jason Gross, 05/29/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jonathan Leivent, 05/29/2016
