coq-club - Re: [Coq-Club] LEM variants vs. proof relevance
  • To: coq-club AT inria.fr
  • Subject: Re: [Coq-Club] LEM variants vs. proof relevance
  • Date: Sun, 29 May 2016 09:53:26 -0400
  • Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f171.google.com
  • Ironport-phdr: 9a23:Z2LxjRKBpcG2CCOYcNmcpTZWNBhigK39O0sv0rFitYgUKfXxwZ3uMQTl6Ol3ixeRBMOAu6MC1rOd7fGocFdDyKjCmUhKSIZLWR4BhJdetC0bK+nBN3fGKuX3ZTcxBsVIWQwt1Xi6NU9IBJS2PAWK8TWM5DIfUi/yKRBybrysXNWC3oLqjqvsqtX6WEZhunmUWftKNhK4rAHc5IE9oLBJDeIP8CbPuWZCYO9MxGlldhq5lhf44dqsrtY4q3wD86Fpy8kVWqLjOq88ULZwDTI8Mmlz6te4mwPESF6t4X0VTmUflFJsDgnb4RfmFsPztS37ted51SSyMsj/TLRyUjOnufQ4ACT0gTsKYmZquFrcjdZ92fpW
On 05/28/2016 10:26 PM, Jason Gross wrote:
Have you considered LEM on hProps?
forall P, (forall x y : P, x = y) -> P \/ ~P
Together with propositional truncation / quotient types, this may give you
want you want. (I think these are similar to your irrelevant_sibling; you
do:
Module Export Trunc.
Private Inductive PropTrunc A := tr : A -> PropTrunc A.
Axiom PropTrunc_trunc : forall {A} (x y : PropTrunc A), x = y.
Definition Trunc_ind {A}
(P : PropTrunc A -> Type) {Pt : forall x y, P x = P y}
: (forall a, P (tr a)) -> (forall aa, P aa)
:= (fun f aa => match aa with tr a => fun _ => f a end Pt).
End Trunc.
Does this do what you want?
So, this relies on the semantics of Private to prevent discrimination/destruction of PropTrunc instances outside the module. This trick scares me a bit. Does native_compute always obey this restriction? It disobeys opaqueness, so that's why I'm suspicious. How does this mix with extraction - will PropTruncs get erased as well as Props?
As for having an induction scheme - that might be useful...
-- Jonathan
