- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] LEM variants vs. proof relevance
- Date: Sun, 29 May 2016 14:11:08 +0000
- Authentication-results: mail2-smtp-roc.national.inria.fr; spf=None smtp.pra=jasongross9 AT gmail.com; spf=Pass smtp.mailfrom=jasongross9 AT gmail.com; spf=None smtp.helo=postmaster AT mail-oi0-f52.google.com
- Ironport-phdr: 9a23:0Ee0AxZZEy0QcYkOA7CxBzH/LSx+4OfEezUN459isYplN5qZpc+8bnLW6fgltlLVR4KTs6sC0LqH9f25EjNaqb+681k8M7V0HycfjssXmwFySOWkMmbcaMDQUiohAc5ZX0Vk9XzoeWJcGcL5ekGA6ibqtW1aJBzzOEJPK/jvHcaK1oLsh7H0psSYPF8ArQH+SI0xBS3+lR/WuMgSjNkqAYcK4TyNnEF1ff9Lz3hjP1OZkkW0zM6x+Jl+73YY4Kp5pIYTGZn9Kq8/VPlTCCksG2Ez/szi8xfZHiWV4X5JcGwNlRwALBLC9wqyCpX4qSz8ufB6wzLLFcLzRLEwHz+l6vE4G1fTlC4bOmthoynsgctqgfcDrQ==
You can throw it in Prop if you want it to be erased in extraction (and then the eliminator also has to target Prop). I believe the private inductive semantics forbid any new pattern matches outside the module. At worst, this will break subject reduction (vm_compute might reject a well typed term, unfolding the induction scheme on neutral terms won't work nicely), but it won't lead to inconsistency.
On Sun, May 29, 2016, 9:53 AM Jonathan Leivent <jonikelee AT gmail.com> wrote:
On 05/28/2016 10:26 PM, Jason Gross wrote:
> Have you considered LEM on hProps?
> forall P, (forall x y : P, x = y) -> P \/ ~P
> Together with propositional truncation / quotient types, this may give you
> want you want. (I think these are similar to your irrelevant_sibling; you
> do:
> Module Export Trunc.
> Private Inductive PropTrunc A := tr : A -> PropTrunc A.
> Axiom PropTrunc_trunc : forall {A} (x y : PropTrunc A), x = y.
> Definition Trunc_ind {A}
> (P : PropTrunc A -> Type) {Pt : forall x y, P x = P y}
> : (forall a, P (tr a)) -> (forall aa, P aa)
> := (fun f aa => match aa with tr a => fun _ => f a end Pt).
> End Trunc.
> Does this do what you want?
So, this relies on the semantics of Private to prevent
discrimination/destruction of PropTrunc instances outside the module.
This trick scares me a bit. Does native_compute always obey this
restriction? It disobeys opaqueness, so that's why I'm suspicious. How
does this mix with extraction - will PropTruncs get erased as well as Props?
As for having an induction scheme - that might be useful...
-- Jonathan
- [Coq-Club] LEM variants vs. proof relevance, Jonathan Leivent, 05/28/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Gérard Huet, 05/28/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jonathan Leivent, 05/28/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Arnaud Spiwack, 05/28/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jason Gross, 05/29/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jonathan Leivent, 05/29/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jonathan Leivent, 05/30/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jason Gross, 05/30/2016
