- To: coq-club AT inria.fr
- Subject: Re: [Coq-Club] LEM variants vs. proof relevance
- Date: Sat, 28 May 2016 13:30:37 -0400
- Authentication-results: mail3-smtp-sop.national.inria.fr; spf=None smtp.pra=jonikelee AT gmail.com; spf=Pass smtp.mailfrom=jonikelee AT gmail.com; spf=None smtp.helo=postmaster AT mail-qk0-f178.google.com
- Ironport-phdr: 9a23:OheEthM2b6ewtPYiFfkl6mtUPXoX/o7sNwtQ0KIMzox0KPj6rarrMEGX3/hxlliBBdydsKIVzbeO+Pm5ACQp2tWojjMrSNR0TRgLiMEbzUQLIfWuLgnFFsPsdDEwB89YVVVorDmROElRH9viNRWJ+iXhpQAbFhi3DwdpPOO9QteU1JTmkb3qsMSKOk1hv3mUX/BbFF2OtwLft80b08NJC50a7V/3mEZOYPlc3mhyJFiezF7W78a0+4N/oWwL46pyv50IbaKvdKMhCLdcET4OMmYv5cStuwOQYxGI4y4+VWMfjhpBBUDh4RDkU5Ht+n/4sex82ySeMMDeQrU9WDDk5KBuHky7wBwbPiI0pTmEwvd7i7hW9Uqs
On 05/28/2016 12:48 PM, Gérard Huet wrote:
What you are toying with in the free Heyting algebra generated by one element
(P).
It is not finite, this is Nishimura’s lattice. Your infinite regress is going
up this lattice, but True is unreacheable by unions of P’s and ~P’s (in
intuitionistic propositional calculus).
P \/ (P \/ ~P -> ~P) is not just stating the obvious, anymore than his sister at
the first level ~P->P.
GH
I confess that that's over my head, so I'm not sure if it helps me towards the goal.
Attached is what I'm working towards. I just need to be sure the lemlike hypothesis does not imply proof irrelevance...
-- Jonathan
Le 28 mai 2016 à 17:47, Jonathan Leivent
<jonikelee AT gmail.com>
a écrit :
Coq.Logic.ClassicalFacts shows that excluded middle (LEM) implies proof irrelevance. I'm working with a form of
proof relevance, but would still like some alternative to LEM - which would allow me to have "forall
P, P \/ something else about P" that would still form an excluded middle in that both sides of the
"\/" could not be true at the same time. Because, it looks like if I can have such a thing, then I can
get the benefits of proof irrelevance without full proof irrelevance: It would allow me to easily find for any
arbitrary Prop P, a P' such that P <-> P' and P' is irrelevant (forall p q : P', p = q). As pointed out in
the "Proof irrelevant Specif?" thread, coincidentally, this is already possible in Coq without any
axioms for all P that are type-decidable ({P}+{~P}) - because that allows a version of P that is a boolean
predicate. The form of proof relevance I'm working with makes it the case for any P that is prop-decidable (P \/
~P : locally LEM). This last bit I'm looking for would make it the case for all P period.
The first thing I though of was "forall P, P \/ (P \/ ~P -> ~P)". Interestingly, this is
not a tautology in Coq (at least tauto doesn't think so), but it seems like it's just stating the
obvious. Could it be possible that "forall P, P \/ (P \/ ~P -> ~P)" does not imply proof
irrelevance? If so, then it's just what I need.
Otherwise, there is an infinite regress of these:
Fixpoint nlem(n : nat)(P : Prop) :=
P \/ (match n with
| 0 => True
| S m => nlem m P
end -> ~P).
Arguments nlem : simpl nomatch.
Lemma nlem0_is_lem : (forall P, nlem 0 P) <-> (forall P, P \/ ~P).
Proof.
cbn. split; intros H P.
all: specialize (H P); tauto.
Qed.
Lemma nlem1_is_ : (forall P, nlem 1 P) <-> (forall P, P \/ (P \/ ~P -> ~P)).
Proof.
Qed.
Lemma nlem_inc : forall n P, nlem n P -> nlem (S n) P.
Proof.
cbn. destruct n.
- cbn in *. tauto.
- destruct n. all: cbn in *; tauto.
Qed.
If not "nlem 1 P", what about "nlem n P" for some high enough n?
As it turns out, I really only need to claim the existence of some arbitrary
"something else about P":
Axiom lemlike : forall (P:Prop), exists (Q:Prop), (P \/ Q) /\ (P /\ Q ->
False).
Might that be safe enough (not imply proof irrelevance)?
-- Jonathan
Require Eqdep_dec. Section PIP. Variable pbool : Prop. Variables ptrue pfalse : pbool. Hypotheses pbool_binary : forall b, b = ptrue \/ b = pfalse. (*Proof relevance of pbool means it can be discriminable:*) Hypothesis pbool_discriminable : pfalse <> ptrue. Let pbool_discriminable_sym := not_eq_sym pbool_discriminable. Lemma pbool_dec : forall (a b : pbool), a=b \/ a<>b. Proof. intros. destruct (pbool_binary a), (pbool_binary b); subst. all:intuition contradiction. Qed. (*An alternative to LEM that hopefully does not imply proof irrelevance:*) Hypothesis lemlike : forall (P:Prop), exists (Q:Prop), (P \/ Q) /\ (P /\ Q -> False). Definition P2pbool P : pbool := match lemlike P with | ex_intro _ _ (conj (or_introl _) _) => ptrue | ex_intro _ _ (conj (or_intror _) _) => pfalse end. (*for any P, piP P is an irrelevant equivalent to P:*) Definition piP(P : Prop) := P2pbool P = ptrue. Lemma piP_iff_P : forall P, piP P <-> P. intro p. cbv. destruct (lemlike p) as (?&()&?). all:intuition contradiction. Qed. Lemma piP_is_irrelevant{P}(a b : piP P) : a = b. Proof. apply Eqdep_dec.eq_proofs_unicity. apply pbool_dec. Qed. End PIP.
- [Coq-Club] LEM variants vs. proof relevance, Jonathan Leivent, 05/28/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Gérard Huet, 05/28/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jonathan Leivent, 05/28/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Arnaud Spiwack, 05/28/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jason Gross, 05/29/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jonathan Leivent, 05/29/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jonathan Leivent, 05/30/2016
- Re: [Coq-Club] LEM variants vs. proof relevance, Jason Gross, 05/30/2016
